international 47 square baler
   / international 47 square baler #1
creek side cattle
strang ok
47 international square baler
I just bought a little 47 international baler and found the needles on it have just the tip broke off does anyone know where I can order parts for this thing from
   / international 47 square baler #2
If the eyes on the end aren't broken out you can braze the ends and grind them back to original contour.
Just make sure that you get them put back on the needle cradle properly and recheck the timing of the baler. I
think that the needle on the early 430 & 435 balers are the same. hope this helps.
   / international 47 square baler #3
I had a 37. Interestingly nearly all the series of those balers are interchangeable. If you don't have anybody around that that collects them then just go to a Case IH dealer as they still carry them...though they are a bit pricey.
(15) WOOD PALLETS (A60432)
(15) WOOD PALLETS...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
Chemical Containers Tank (A57148)
Chemical...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A59575)
2005 PETERBILT 379...
