International 385 PTO problem
   / International 385 PTO problem #1
paintedhorse
ms
intl 385
I replaced the leaking hydraulic line going to my steering, and also changed the hydraulic/transmission oil, and now the PTO won't work at all. The steering and lift work fine. The mechanical linkage seems to be fine. The handbook states the PTO hydraulically egages the flywheel to turn the PTO, so I'm hoping the problem isn't too serious. Any ideas what the problem might be? Thanks.
   / International 385 PTO problem #2
I would keep working the lever for the PTO and see if there might be any air trapped inside. The air should purge itself after use.
I have seen loader take about 5 to 10 cycles to purge the air.
   / International 385 PTO problem #4
Check for dirt in your steeringreturnline where it enters the mcv body. If that checkvalve is not working your pto will also not working...remove the pipe and then the union and the cage ...spring ....poppet............poppet must slide free into the cage ........clean and refitt in correct order
UNUSED SWICT 84" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 84"...
2016 John Deere Gator 825i 4x4 Utility Cart (A53421)
2016 John Deere...
2018 JLG G9-43A (A47477)
2018 JLG G9-43A...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A55218)
2022 MAXXD BD14...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55788)
2013 Ford F-150...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
