International 3500a Pto?
/ International 3500a Pto? #1
dodgeram945
Rothbury, MI
International 3500A, Case 580CK, Satoh Beaver
I have an International 3500a with hydro drive and 3 pt hitch. I was wondering if it would be possible to put in the 2 speed ptos. The tractor has covers over where the ptos should come outin the back. I'm curious if anybody has a 3500a with the 2 speed ptos or if there is an agriculture version of this tractor out there that you could put the parts into this tractor. I would like to get the ptos working so I have a multi purpose tractor because I have too much money into this one with rebuilt engine and new tires. If anybody has info it would be greatly appreciated.
/ International 3500a Pto? #2
The transmission/differential gears and housing is the same as a International 574 farm tractor. To install a PTO in a 3500A, you would need to find a 574 Hydro and switch over all the parts which would be a big job since it uses a live shaft from the flywheel through the hydro transmission, back through the transaxle to a hydraulically operated PTO clutch. You will need the linkage to ooperate the clutch along with the parts at the rear of the tractor The PTO will be a single speed 540RPM.
Bill
/ International 3500a Pto? #3
Early 574-674's did have the 540-1000 rpm pto's available in them but I don't remember the hydro till the 84 series.
Chevy 2500 HD 4WD (A63689)
Chevy 2500 HD 4WD...
2004 MACK CV (GRANITE) KILL TRUCK (A65643)
2004 MACK CV...
1997 Chevrolet Kodiak C6500 Aerial Crane (A62613)
1997 Chevrolet...
2021 PETERBILT 367 (A65643)
2021 PETERBILT 367...
PRESURE WASHER TRAILER (A65643)
PRESURE WASHER...
2013 PETERBILT 367 (A65643)
2013 PETERBILT 367...
