International 3500a Pto?
/ International 3500a Pto? #1
dodgeram945
Rothbury, MI
International 3500A, Case 580CK, Satoh Beaver
I have an International 3500a with hydro drive and 3 pt hitch. I was wondering if it would be possible to put in the 2 speed ptos. The tractor has covers over where the ptos should come outin the back. I'm curious if anybody has a 3500a with the 2 speed ptos or if there is an agriculture version of this tractor out there that you could put the parts into this tractor. I would like to get the ptos working so I have a multi purpose tractor because I have too much money into this one with rebuilt engine and new tires. If anybody has info it would be greatly appreciated.
/ International 3500a Pto? #2
The transmission/differential gears and housing is the same as a International 574 farm tractor. To install a PTO in a 3500A, you would need to find a 574 Hydro and switch over all the parts which would be a big job since it uses a live shaft from the flywheel through the hydro transmission, back through the transaxle to a hydraulically operated PTO clutch. You will need the linkage to ooperate the clutch along with the parts at the rear of the tractor The PTO will be a single speed 540RPM.
Bill
/ International 3500a Pto? #3
Early 574-674's did have the 540-1000 rpm pto's available in them but I don't remember the hydro till the 84 series.
Komatsu D65EX Dozer (A66285)
Komatsu D65EX...
2024 BOBCAT S76 R-SERIES SKID STEER (A64279)
2024 BOBCAT S76...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
1000 Gal Fuel Tank w/ Electric Pump (A64127)
1000 Gal Fuel Tank...
Electric Hoist (A66408)
Electric Hoist...
