International 2444 hydraulics
/ International 2444 hydraulics #1
Dezlsmkr7127
international
Hi guys I’m new here and have a question. I have an old 2444 with the 3 point bouncing with any kind of weight on it. I’ve read things like the piston ring etc could cause this. I’m going to attempt to repair this myself and was looking for some pointers. If I tighten that left hand valve it will hold it up with no bleed off. Where would I start on this project?
/ International 2444 hydraulics #2
I had a 2444 about 20 years ago but don't remember much about it. The "left hand valve"? Does that regulate the lowering speed? If so, and tightening it will not allow the 3-point to drop, I think your problem is in the valve not the cylinder, or possibly the sensing circuit. Shutting the valve holds the oil in the cylinder. If the cylinder was leaking, it would still drop with that valve closed.
I assume that’s what it does it’s that little turn valve down on the lift unit. How could a person test that valve? Or am I just to the point of tearing into it and seeing if I see anything?
/ International 2444 hydraulics #4
The 3-point valves are usually right under the seat. Follow the raise/lower lever down and any linkage to where it enters would be the valve. I would guess there to be a spool valve, springs, possibly check valves. Possibly a pressure relief valve. I would try to find a parts break down. A hydraulic circuit diagram would be helpful also. I think a 2444 is just the industrial version of an ag 444. You might have better luck searching for info on that model. I doubt there will be any test ports or any way to test it. I may be as simple as a piece of trash in the valve or a bad O-ring.
/ International 2444 hydraulics #7
That’s is extremely helpful!!! My question is now, shy of seeing a visual issue with an oring how would I know I’d say that control valve was bad causing bleed back? I guess just proccess of elimination?
I would replace every o-ring I came to. Be aware that hydraulic 0-rings are usually Duro-90 where your standard o-ring kits and such are only 70s. I would try to get them from a hydraulic store or OEM, but that maybe tough to do OEM. Look for scored or pitted parts. Polish or replace as needed. It looks like you will have the piston out so might as well replace the packing there too. Without knowing what to look for, it makes it hard. If I was tearing it apart as far as the video goes, I'd be through.
It appears there is a substantial amount of fluid coming out of the rh lift arm. I will get this thing apart and go all through it. Replace any questionable o ring. Thank you for the help
/ International 2444 hydraulics #9
My 424 leaks like that from the levers that operate the 3 point and draft control, but it doesn't have your bouncing symptoms.
/ International 2444 hydraulics #10
Please show us lots of photos and report on the repair. I'm sure there are others besides me who would be interested. Good luck!
I will do!!
/ International 2444 hydraulics #12
Take a look at the bushings. They are probably worn and the excess clearance damages the seals or O-ring. Hopefully the rock shaft isn't worn too.
/ International 2444 hydraulics #13
After you have gone through the hydraulics you might want to add a vent to the system. As far as I know there was no provision for venting in the original design. I don't know for sure but I think it is possible for some amount of pressure to build up in the hydraulic fluid reservoir which in turn could worsen any leakage.
/ International 2444 hydraulics #14
That is a great idea I had not thought of that. :thumbsup:
/ International 2444 hydraulics #15
This is what I did on mine. It is hard to see but I attached a piece of cloth on the end of the piping set-up.Tractor 005.JPG
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
TEST YOUR BID BUTTON! (A64278)
TEST YOUR BID...
CATERPILLAR D9T CRAWLER DOZER (A64279)
CATERPILLAR D9T...
2014 Dodge Caravan Van (A64557)
2014 Dodge Caravan...
2012 18ft Gastron Boat with 18ft Magic S/A Boat Trailer. (A64557)
2012 18ft Gastron...
2021 John Deere 4044M (A64126)
2021 John Deere...
