International 140
   / International 140 #1
Crw
Farmall 140
I recently rebuilt the carb on my international 140 and it ran good the I installed a ignition tune up kit and now I have no spark I don't know if I could have fried the could or I did somthing wrong with setting the points inside the distributer if any one has any info on this it would help me a great deal
   / International 140 #2
I set the points on my IHs .015 to .018. And make sure the rotor is all the way down. That got me a few times.
   / International 140
When I set the points the does the distributer shaft need to be turned so that is on one of the corners of the square shaft is holding the points open before I set the points
   / International 140 #4
Mine have hex shaped distributer shafts, but yes the points must contact a corner point. The easiest way is to "bump" the key. You may have to slightly adjust the point specs if your dis shaft corners are worn.
   / International 140 #5
The condensor should be okay unless you accidentally grounded it with the ignition switch still on when you were bumping it to set the points. It sounds more like an improper gap setting or a loose connection when you put the new parts in.
   / International 140
Yeah after I rebuilt the carb and got it back together I started it and it ran then I had the ignition problem u hit the nail on the head I fried the condenser then once I got that fixed and took it out for a spin the engine was pulsing agin and gas was poring out of the carb I adjusted the governor and it seems to be running good now good tractors but can through you for a loop sometimes thank everyone for your help
   / International 140
Sorry my luck ran out I was out mowing and it was running good after I adjusted the gov then it started pulsing agin anyone have any ideas of what I should do to fix this or what exactly it could be
   / International 140 #8
Check your float adjustment in the carb. If it was pouring gas earlier, that sounds like the float was set to high. I don't believe the governer adjustment had anything to do with it flooding gas through the carb.
   / International 140
The gas stoped pouring from the carb but I just can't get it to stop pulsing when it is under load it gets so bad when mowing up hill that it almost stalls until I push the clutch in then it will smooth back out for a bit then it does it agin when I take off do u think it is the carb or governor
   / International 140 #10
Did you change the fuel filters
2013 KENWORTH T800 TRI AXLE CRANE TRUCK (A52472)
2013 KENWORTH T800...
Agco 8200 Flex Grain Platform (A50514)
Agco 8200 Flex...
2014 FREIGHTLINER S/A SERVICE TRUCK (A51243)
2014 FREIGHTLINER...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2019 GENIE...
1999 Freightliner Service Truck (A50514)
1999 Freightliner...
