Intermittent won't go forward or reverse
   / Intermittent won't go forward or reverse #11
I had a similar problem a while ago with my Series A toolcat. I ultimately determined it was in the TICS system and removed the safety interlocks from the arm rest. I bound the two halves together and never experienced a problem. I reinstalled them again and my problem came back. My belief is the switch became weak and unresponsive to the magnet from the other half of the system. Purchased a new TICS switch, installed it and have not experienced the problem to date.
How exactly did you do this. I am getting quite desperate and thinking about doing this now. I have gone down a couple different rabbit holes with no luck.
   / Intermittent won't go forward or reverse #12
Any luck Andy?
Terms & Conditions of (Buying through EquipmentDealz Auction) Continued (A59213)
Terms & Conditions...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
JMR 40" Mini Grapple (A57149)
JMR 40" Mini...
New/Unused CFG Industrial H12R Mini Excavator (A57453)
New/Unused CFG...
FRONT MOUNT TANK AND BRACKET OFF JOHN DEERE 4020 (A52708)
FRONT MOUNT TANK...
HAND TRUCK, CHAIN & MISC (A58374)
HAND TRUCK, CHAIN...
