Intermittent treadle failure
/ Intermittent treadle failure #1
TractorGolf
Lewisberry, PA
PT 425, 154 Cub LowBoy
The 425 treadle valve seems to loose position during operation. Depressing the pedal to go forward or reverse, motion is lost.
It can be reset by turning off the engine and then re-starting the engine.
Has anyone had this problem or any suggestions to remedy this problem?
/ Intermittent treadle failure #3
Would air in the lines be possibly causing this?
Is it possible that there is a piece of something that pressure makes block a port but when you turn off the engine, it falls off?
Does it work properly right away or does the oil have to cool down?
Ken
/ Intermittent treadle failure #4
Yeah, that's why I'm trying to ask if the treadle is hydraulic or cable. If it's hydraulic, purge the pump and see what happens.
The treadle is hydraulic.
After going through some troubleshooting I called Power-Trac.
I spoke with Terry at Power-Trac and he mentioned it may be a scratch on the variable pump piston.
At this point in time I'll muddle through winter and address the problem if it continues to get worse.
2019 INTERNATIONAL 4300 26FT BOX TRUCK (A59910)
2019 INTERNATIONAL...
Bush Hog 244-7QT Front End Loader (A64047)
Bush Hog 244-7QT...
Safety Basket Forklift Attachment (A61572)
Safety Basket...
2022 John Deere X730 Lawn Mower (A63116)
2022 John Deere...
2018 HINO SA (A58214)
Box of Transport Ratchet Straps (A59230)
Box of Transport...
