Intermittent treadle failure
/ Intermittent treadle failure #1
TractorGolf
Lewisberry, PA
PT 425, 154 Cub LowBoy
The 425 treadle valve seems to loose position during operation. Depressing the pedal to go forward or reverse, motion is lost.
It can be reset by turning off the engine and then re-starting the engine.
Has anyone had this problem or any suggestions to remedy this problem?
/ Intermittent treadle failure #3
Would air in the lines be possibly causing this?
Is it possible that there is a piece of something that pressure makes block a port but when you turn off the engine, it falls off?
Does it work properly right away or does the oil have to cool down?
Ken
/ Intermittent treadle failure #4
Yeah, that's why I'm trying to ask if the treadle is hydraulic or cable. If it's hydraulic, purge the pump and see what happens.
The treadle is hydraulic.
After going through some troubleshooting I called Power-Trac.
I spoke with Terry at Power-Trac and he mentioned it may be a scratch on the variable pump piston.
At this point in time I'll muddle through winter and address the problem if it continues to get worse.
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
2022 21ft Scout 210 Dorado Boat with 2011 18ft Magic S/A Boat Trailer (A64557)
2022 21ft Scout...
CATTLE HEAD GATE (A64278)
CATTLE HEAD GATE...
(128) BOARDS OF 1"x6"x8" PONDEROSA PINE (A65055)
(128) BOARDS OF...
2020 Ford Fusion Hybrid Sedan (A64557)
2020 Ford Fusion...
2023 JOHN DEERE 550P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
