Intermittent Failure
   / Intermittent Failure #1
JimBoy
Ossining, NY
John Deere 3720
Hi all. I have a JD3720 with a backhoe. The last two times I started the tractor, the left stabilizer would not raise. The lever would not move in that direction. After about 20 minutes, it would work. What is going on?
   / Intermittent Failure #2
water/ice in the system is a guess...
If that is the case, do I need to flush the entire hydraulic system?
   / Intermittent Failure #4
I would flush and use recommended fluid for your climate.
   / Intermittent Failure #5
Most of the time it is water in the spring cup or in the linkage system, not in the hydraulics. Your system would have to be in BAD shape for a valve spool to freeze up. Personally I have never seen it. Almost all the time it is the detent or spring center cup on the back of the spool [opposite the linkage hook up] that has water in it. CJ
   / Intermittent Failure #6
I totally agree with this....
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A51694)
2022 Forest River...
BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox XHD-78HF...
2016 FORD INTERCEPTOR (A51406)
2016 FORD...
2000 Sterling L9513 Winch Truck (A55218)
2000 Sterling...
2011 CHEVROLET EXPRESS SERVICE VAN (A51406)
2011 CHEVROLET...
