INTERMITENT WIPERS?
/ INTERMITENT WIPERS? #1
dirtworksequip
Wheeling, WV
2006 JD 3520 w/cab & 300CX loader. 1995 JD 870 w/440 loader & 8b backhoe.JD 455 w/54" mower deck.
Is there anyway to incorperate some kind of delay or reostat into a standard one speed wiper to make it an intermitent wiper?
/ INTERMITENT WIPERS? #2
I've seen aftermarket add-ons for cars, don't see why you couldn't do it for your tractor.
Thanks Will, I see your lurkeritis has advanced to lurkeritis-uwritus.
/ INTERMITENT WIPERS? #5
dirtworksequip said:
lurkeritis-uwritus.
Ya, lately I've had quite a bit of free time on my hands.
Been nursing a fractured rib. 6 down and another 2 weeks to go.
Get well soon! Thanks for the help.
/ INTERMITENT WIPERS? #7
Hope you're better soon.JC Whitney has one I've used for several years(much cheaper)
/ INTERMITENT WIPERS? #8
1*Wire one of those switches that controls the brightness of your dash lites into the wipers.
or 2* wire in a turn signal flasher.
/ INTERMITENT WIPERS? #9
You can make one for about ten bucks with a TTL 555 timer chip, some resistors, capictors, potentiometer, relay and a switch.
Here's a link to a kit for under $15.00.
Moss, good idea. I don't have enough knowlege of elec. to put something like that together. Thanks for the thought.
/ INTERMITENT WIPERS? #11
Mossroad has the right idea.. a rheostat would be a super poor choice to slow wipers.
A timer triggered module ( can be built with a compariter and a slow charge cap circuit.. Can also be built with a mosfet, setup as a PWM. Way better motor controllers because you have full supply voltage and current.. just on time is sliced up.. vs a rheostat that drops voltage and reduces current.
Soundguy
/ INTERMITENT WIPERS? #12
Soundguy
I've used them to control wipers and heater fans.
/ INTERMITENT WIPERS? #13
Soundguy
I built several of these 20 years ago, back before most cars came standard with wiper delays. GM cars just put 12V onto the wiper relay to turn on their wipers. All this thing does is let the 12V out to the wiper relay at intervals that are adjusted by the potentiometer. Mine were adjustable from 1 to 20 seconds. I also had a switch and circuitry to make the wiper swipe twice, then wait. You know how sometimes one swipe almost gets it, but just quite not enough... ;)
/ INTERMITENT WIPERS? #14
A PWM is a -way- better motor control than a resistive element, as it still allows the motor to draw the same current.. and thus have less chance for stall at slow speeds on the brush type dc motors.
For ac stuff.. triac based controllers are good and easy to rig.
Soundguy
2022 EZ-GO ELITE...
5-Pointed Star Metal Decorative Sign (A64557)
5-Pointed Star...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A64278)
2023 JOHN DEERE...
2025 60 Gallon Poly Diesel Tank w/ 12v Pump, nose, Nozzle and Pump (A64557)
2025 60 Gallon...
2019 VOLVO L90H WHEEL LOADER (A65053)
2019 VOLVO L90H...
2001 Pierce Tilt Crew Cab Pumper Fire Truck (A61573)
2001 Pierce Tilt...
