Interlock vs. throwing the main circuit breaker for generator powering a house
   / Interlock vs. throwing the main circuit breaker for generator powering a house #11
It looks like this...
Mine was installed when I bought the building, but I have never used it. If my power ever does go out for a long period of time I will have to build a cord before using it.
Until reading RickB's comment below I never really thought about how mine worked; but I have heard that this can still allow power to feed back into the utility line.
This is true, as the interlock is mounted to the panel cover, and if the cover is removed, both breakers could be in the 'ON' positions at the same time, allowing back-feed to the power lines.
   / Interlock vs. throwing the main circuit breaker for generator powering a house #12
That's simply a case of user oversight. In the instance which RickB cited you can still get some feed even if my interlock is used properly.
I also have been told though that the power company will ground the lines before working on them to prevent the risk of injury. I don't know if that is true though.
   / Interlock vs. throwing the main circuit breaker for generator powering a house #13
I have NEVER understood how, when BOTH hot lines are interrupted by tripping the main breaker, any power can flow through the neutral.
   / Interlock vs. throwing the main circuit breaker for generator powering a house #15
Will physically pulling the main breaker prevent that? I'll admit that I have gotten complacent. Our Coop is very proactive so that in the 25+ years I've lived up here the longest that my power has been out was 12 hours- and that was a one time thing. The only thing I really need my generator for is to run my fridge and freezers, and I can run an extension cord for that.
   / Interlock vs. throwing the main circuit breaker for generator powering a house #16
My power system is also layed out such that in interlock won't fit the bill. Main breaker is at the house, generator feed is at the barn, which is fed from the house. Things are clearly marked, wife and oldest son understand the process and order of events clearly.
I agree. I used to have the same set up, had to feed from a sub-panel in my remote garage. I was going to place an interlock on the main panel incorporating the sub panel breaker but never got around to it. I placed laminated magnetic instruction sheets on the panel door, the sub-panel door, and the generator, just in case I wasn't around and my wife had to start it. She understood it well and the instruction sheets just served as a reminder, but gave me a little peace of mind.
In our house now, I feed directly from the main panel, so I opted for the interlock. It is much better than the transfer switch because we didn't have to choose what circuits to power. We can run the whole house but we opt to stagger certain items. Like no need to run the dishwasher or washer and other appliances at the same time. Or don't use the toaster, and the coffee maker when the fridge is powered up. The basics all work fine together. We use a 10000 surge, 8500, and haven't heard it idle up much.
   / Interlock vs. throwing the main circuit breaker for generator powering a house #17
They both will accomplish the same thing. However, an interlock is your safest bet. An interlock eliminates the chance of human error by forgetting to turn off the main breaker.
Exactly and that is why, in most places, an interlock is required by code.
   / Interlock vs. throwing the main circuit breaker for generator powering a house #18
I have a 400 amp service all electric home.
No main interlock but I have a subpanel with 3 position breakers so I can select which critical circuits to power... not as convenient but then I only have a Honda 5000 Watt Genset.
Don't see these as often but were very common 25 years ago... gives me well pump, refrigerator, lights/convenience
http://img2.wfrcdn.com/lf/50/hash/1...r-Generator-with-6-Circuit-Breaker-51406C.jpg
   / Interlock vs. throwing the main circuit breaker for generator powering a house #19
An interlock is an acceptable alternative to a transfer switch in some areas. Stating an interlock is the safest device is not valid. A transfer switch is a complete, positive disconnect from the power grid.
Why a Generator Needs a Transfer Switch
   / Interlock vs. throwing the main circuit breaker for generator powering a house #20
Is there a difference in safety if I just turn off the main 200amp circuit breaker versus having a generator interlock installed? My understanding is the danger of backfeeding power to the outside power pole and transformer.
Thanks,
JFoy
Yes, there's a difference in safety, because human error is involved and you could accidentally back-feed the lines.
A simple and inexpensive solution is a lockout like this. They are under $75. You can't turn on the generator breaker unless you turn off the main breaker in the panel first. Perfectly legal, elegant, and simple.
587941d1548011055-interlock-vs-throwing-main-circuit-472de12b-4d7d-4c99-8171-91ed432e45bd
Toro Zero Turn Mower (A50324)
Toro Zero Turn...
(INOP) NEW HOLLAND B95 BACKHOE (A50459)
(INOP) NEW HOLLAND...
LINK BELT LB-98 LOG LINE YARDER WITH MOTORIZED CARRIAGE (A51222)
LINK BELT LB-98...
2012 FORD F-650 SUPER DUTY BOX TRUCK (A51243)
2012 FORD F-650...
2016 HINO 268 BOX TRUCK (A51219)
2016 HINO 268 BOX...
INSPECTION (A51572)
INSPECTION (A51572)
