Inter-axle ratio
/ Inter-axle ratio #1
ags1517
Does anyone please know what the inter-axle ratio should be for a Kubota L2850. I want to run Goodyear Soft Trac 44-18-20 on the rear, and am trying to work out what the front size should be.
Thanks
/ Inter-axle ratio #2
Can you figure the difference in percentage of the old rear tires compared to the old front tires? Example, old rear tires are 48'' dia. old front tires are 30' dia. Front tires are 62.5 % as big as rear tires. New rear tires 50''. New front tires would be 31.25" If you want more or less lead or lag in the front tires, add or subtract the needed percentage. On stock car tires we would use the circumference of the tire because that is a more accurate measurement.
2024 CASE TV370B SKID STEER (A65053)
2024 CASE TV370B...
2009 Ford F-150 Pickup Truck (A64194)
2009 Ford F-150...
MISC PALLET OF TRUCK PARTS (A65643)
MISC PALLET OF...
Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
Warren Power...
12 in. WRXLS Excavator Bucket Attachment (A64194)
12 in. WRXLS...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
