Buying Advice Inter 434D
/ Inter 434D #1
greggyy
Sydney, NSW
Compacts
Hi all...looked and drove the inter 434d
All seems not bad
4k for a machine with 4k hrs......
No major leaks it seem....started ok an no odd sounds.
Rear links had weight and machine would bump or jerk every say 10 or so seconds.....is to do with hydraulucs.....if implement put all the way down it stops.....if half way it will bump or jerk machine every 10 secs or so........as I was looking at rear i could see rear implement slowly lowering before the jerk raised it say an inch or so to prior position....
So is this serious ?
I have no idea what position the levers and hydrailic buttons should be in......
/ Inter 434D
Also is 4000 hrs a lot for a machine from 70s ? Seems no and have no idea if looked after or rebuilt etc.
2016 Ford F-150 Extended Cab Pickup Truck (A64557)
2016 Ford F-150...
DYNAPAC  CP271 PNUEMATIC ROLLER(INOPERABLE) (A67714)
DYNAPAC CP271...
2026 KH72 72in Hydraulic 4-Way Clamshell Bucket Skid Steer Attachment (A66734)
2026 KH72 72in...
2013 FREIGHTLINER CORONADO 122 SD (A67714)
2013 FREIGHTLINER...
(INOP) LAYMOR SM300 RIDE-ON SWEEPER (A65054)
(INOP) LAYMOR...
Unused 2021 MK Martin Axis 5-6 Hydraulic Took Arm Tractor Attachment (A66734)
Unused 2021 MK...
