Intelligent Design
/ Intelligent Design #1
daedong
South Australia
I need more traction travelling over sand with my DK50. My problem is this though I also do about 50% of the tractor work on bitumen (tar, black, whatever you call it in the north).
The list of tire options goes on and on eg. type of tread, loaded or not loaded yet there appears to be no really good multi use option. Do you think someday intelligent tires will be available that maybe can automatically change pressures, tread etc when they encounter different ground or loads. At present it is a real tire compromise for multiple use tractors.
/ Intelligent Design #2
daedong
Now that is a case of intelligent design that makes real sense. /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
Vernon
/ Intelligent Design #3
daedong,
</font><font color="blue" class="small">( Do you think someday intelligent tires will be available )</font>
Hey....if you wait loooong enough...some say anything can happen /forums/images/graemlins/smirk.gif
Kevin
/ Intelligent Design #4
Im yet to find an intelligent tractor let alone an intelligent tire. I cant even hold a converstion with my tractor, it just grumbles all the time /forums/images/graemlins/confused.gif
/forums/images/graemlins/grin.gif
/ Intelligent Design #5
"My problem is this though I also do about 50% of the tractor work on bitumen (tar, black, whatever you call it in the north)."
It's called asphalt in my neck of the woods.
/ Intelligent Design #6
Vin,
I know what you need. Do a search on "Mach-5", secondary search "Speed Racer". The Mach-5 had ability to change tread type while in action. I believe it was the "C" button /forums/images/graemlins/grin.gif
Is Bitumen like chip seal? My road is chip seal. I have about 6" of compacted gravel base(3/4AB-3/4 gravel with finings in it). Over that they lay a coat of thick oozy oil, and then place chipped rock in/over the oil.
/ Intelligent Design #8
</font><font color="blue" class="small">( It's called asphalt in my neck of the woods. )</font>
It's blacktop here in Vermont. Asphalt is what you go see a proctologist about.
/ Intelligent Design #10
Or asphelt.
"Listen lady, we're only here to pave. Now how do you want your asphelt?"
Real quote, thought the boss was going to have kittens. /forums/images/graemlins/shocked.gif
2018 Chevrolet Tahoe SUV (A64194)
2018 Chevrolet...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
3pt 5-Shank Subsoiler (A64127)
3pt 5-Shank...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
2020 VOLVO EC200EL EXCAVATOR (A64279)
2020 VOLVO EC200EL...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A61567)
iDrive TDS-2010H...
