Insulating existing metal building
   / Insulating existing metal building #1
Kfbeal
South Texas
2005 JD 5103
We built a 30x40 metal garage for our house, since our house is of all-steel construction to match. It is a red-iron with purlins running horizontally on the open walls. We didn't insulate the walls at the time, but the roof has the bubble wrap/foil backed insulation with vapor barrier.
What would be the best way to insulate now after it's been up for 7 years? We had a cold snap and it was 35 degrees in there and I'd like for it not to be. lol I'd also do this on the overhead doors 9' x 18'.
Could a person somehow glue the blue foam board? Referring to something similar to this: R-Tech at Lowe's: 2" x 8' x 4' Insulated Sheathing
Or should I get some of the same I have on the roof and just start pulling side panels loose and use that?
Any ideas or suggestions? Anyone done this before?
   / Insulating existing metal building #2
You don't think that global warming will fix that problem, eventually? :)
A pic or two of what you have might help a lot.
   / Insulating existing metal building #3
I am going to use closed cell foam insulation for my exterior walls of my metal building. It has the highest R factor per inch and seals out air penetration. It is also the most expensive form of insulation. I am going to use blown in insulation for the drop ceiling.
We have 48 days on average when the temperature gets below zero each years, so insulation is very important here.
   / Insulating existing metal building #4
Good choice on the foam.:) It eliminates a laundry list of issues with other types of insulation against metal. I have a friend down below who is in the business and have learned some good things from him.
   / Insulating existing metal building #5
I would have spay foam applied.
Chris
   / Insulating existing metal building #6
What's the name of this foam? I had my house done with "ICYNENE", which stays flexible and the agent that "foams it up" is water/steam. Two liquids come together at the spray nozzle, has to be at the right temperature. I think technically it's a open cell foam.
Need to insulate a new outbuilding in progress, want to use this. I have wood/steel walls, and have the white bubble wrap on the ceiling.
Pete
I don't have a good one, but here's one when hurricane rita was coming a few years ago, thus all the chaos.
I don't plan to stud it out so it would have to be something kinda tough or not bulky.
2006 KOMATSU WA200-5 WHEEL LOADER (A52705)
2006 KOMATSU...
2022 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A52377)
2022 Allmand Bros...
2016 Nissan Pathfinder S SUV (A50324)
2016 Nissan...
OLIVER DAHLMAN LOT NUMBER 244 (A53084)
OLIVER DAHLMAN LOT...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
