Quick Hitches Instructions for Speeco 3 Pt Quick Hitch?
   / Instructions for Speeco 3 Pt Quick Hitch? #1
sncdoc
I just bought one of the SpeeCo Cat 1 Quick Hitch (HF 141101, I think) and there were no instructions or booklet at all with it. Is there supposed to be one?
Quick question about it for now. It looks like I will need a set of adapter bushings to permanently mount on each piece of equipment that needs one to fit the quick hitch. Is this correct?
Doug
   / Instructions for Speeco 3 Pt Quick Hitch? #2
Doug
Yes, the 141101 quick hitch should have come with a set of 2 adapter bushings and the y-shaped adapter bracket. If you bought it new, call who you bought it from and let them know you are missing parts. If it's used, you'll just have to go to TSC or a similar store and buy some for your implements.
The 141160 Cat I doesn't require the bushings and doesn't come with the adapter.
Giyi Mini Grapple (A57149)
Giyi Mini Grapple...
2011 Ford Crown Victoria Sedan (A54815)
2011 Ford Crown...
EZ GO Terrain 1000 Utility Cart (A56857)
EZ GO Terrain 1000...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A59228)
2010 Turfco...
2013 MACK CHU613 BOBTAIL VACUUM TRUCK (A58214)
2013 MACK CHU613...
Bigfoot Plastic Baler (A57149)
Bigfoot Plastic...
