Quick Hitches Instructions for Speeco 3 Pt Quick Hitch?
   / Instructions for Speeco 3 Pt Quick Hitch? #1
sncdoc
I just bought one of the SpeeCo Cat 1 Quick Hitch (HF 141101, I think) and there were no instructions or booklet at all with it. Is there supposed to be one?
Quick question about it for now. It looks like I will need a set of adapter bushings to permanently mount on each piece of equipment that needs one to fit the quick hitch. Is this correct?
Doug
   / Instructions for Speeco 3 Pt Quick Hitch? #2
Doug
Yes, the 141101 quick hitch should have come with a set of 2 adapter bushings and the y-shaped adapter bracket. If you bought it new, call who you bought it from and let them know you are missing parts. If it's used, you'll just have to go to TSC or a similar store and buy some for your implements.
The 141160 Cat I doesn't require the bushings and doesn't come with the adapter.
12' CONTAINER (A52706)
JOHN DEERE 544G WHEEL LOADER (A58214)
JOHN DEERE 544G...
Amada M-3060 Mechanical Metal Shear (Japan) (A59213)
Amada M-3060...
LOT: Steel Work Bench w/Contents, 40" x 75" (A59076)
LOT: Steel Work...
Giyi 59" 4-N-1 Bucket (A57149)
Giyi 59" 4-N-1...
Eagle Weathervane (A55853)
Eagle Weathervane...
