Instructions for installing work lights
   / Instructions for installing work lights #11
Yes thanks for the pics and ideas on mounting lights to ROPS.
I located the wires at the back of my B2710 and already have a 50W Hella work lamp with a built in switch that I used to use on the back of my Land Rover. I would also like to install 2 forward facing 50W lights and control everything with a 3 way switch. Can you run 2 50-55W lights at the same time thru the existing wire harness? Is the alternater able to keep up with the head lights and 2 additional 50W lamps?
Thanks,
Barnett
   / Instructions for installing work lights #12
I only used one 55 watt light to the front and one to the rear, but if I remember right, the fuse, wiring, etc. is quite capable of handling two at a time. If you check your manual, it shows the rating on the fuse at least (20 amp?).
PALLET TOTE OF JARS & MISC (A58374)
PALLET TOTE OF...
LOT OF TIN (A58374)
LOT OF TIN (A58374)
John Deere 5100M (A53317)
John Deere 5100M...
JOHN DEERE 750 GRAIN DRILL (A58216)
JOHN DEERE 750...
PALLET OF MISC PARTS (A58374)
PALLET OF MISC...
378721 (A54865)
378721 (A54865)
