Installing yard hydrant
/ Installing yard hydrant #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
I have this list of to does, but never done it, anything missing?
- use 3/4" black flexible pipe to run the water
- sand under and over the pipe
- plastic orange tape in the ground to indicate the pipe for future digging
- to connect the pipe to the hydrant use 3/4" brass elbow with adapters (if I can actually find one:))
- install the hydrant, secure it with a piece of rebar to make sure it stays vertical
- turn the water on, check for leaks
- fill the hole with gravel making sure the drain hole is not plugged with dirt or anything
Also planning to have a shot off valve in house.
Any word of experience or suggestion?
/ Installing yard hydrant #2
Sounds like a good list. I'd have another person on hand to hold the thing steady after you connect it up while you are testing it for leaks. Other than that, have fun!
/ Installing yard hydrant #3
Take care unrolling the plastic pipe, it can kink easily, creating a pin hole leak.
For the speacial adapter, use a "street ell" with a barbed end that will slide into the ABS hose, and use 2 radiator clamps to secure it. You can get the fittings at almost any farm store as well as Lowes and Home depot.
I used a "T" post to secure mine and keep it straight, it ran to about 6" lower than the hydrant handle.
Mark
/ Installing yard hydrant #4
Put a check valve between the line and the hydrant, as a safety precaution.
/ Installing yard hydrant #6
I don't know what the codes are there but here you have to have a shut off close to the hydrant. When mine was put in they put the shut off about two feet from the hydrant and then put a 6" green PVC pipe up to the surface. I sure am glad that they did. So far one of the work crew backed into one hydrant and I broke one when a hose hung on the tractor and pulled on it. All of mine have T posts driven beside them to where they are level with the top of the pipe by the handle. The T posts are then wired to the pipe. I think that stainless pipe clamps would work real well also.
/ Installing yard hydrant #7
Almost forgot. Put an elbow turned down in the drain hole. That way the sand and other junk won't get into the drain.
/ Installing yard hydrant #8
In Illinois yard hydrants are illegal with out a backflow device before it, but then again what’s not illegal in Illinois!
There are good reasons for this law, you can back siphon contaminates into your water lines with the weep hole below surface water. There have been deaths as a result of this happening. Best example I can think to illustrate this would be a E.coli issue The spinach problem some months back would be one example that has been in the news. Anytime you have pig, horse, cattle, etc. lots there is water from the hydrant and waste from the animals on the ground in the area around the hydants, that mix can soon find their way to the weep hole level.
Sleep well tonite! thats way I try to drink beer instead of water. :D
/ Installing yard hydrant #9
See like Jerry said, junk in the drain!
/ Installing yard hydrant #10
Mark
I don't think its ABS but rather HDPE or high density polyethylene
/ Installing yard hydrant #11
Bill,
The way these are designed, the only contamination would be at the hydrant. The rubber stopper is either blocking the fresh water flow or the tube drain. Other wise in the on position water would blast out the drain. So as you turn on the water, fresh will flush the tube. So as long as you don't drink the water from the hydrant, I can't see an issue. But you are correct, the bottom of the hydrant tube is filled will ground water. When I have replaced mine in the past, I had to bail the muddy pit. This muddy water is quickly flushed from the tube and I drink from mine all the time. Just not instantly after turning in on!
A flat pad of concrete is a good idea just below the surface. I have ripped one hydrant out as the other poster by catching a loose garden hose with the garden tractor:(
I do like the 'frost free hydrants" over the convential wall mounted shut offs. I can never remeber to keep disconneting the hose on those dang things and replace them nearly every year.
Patric T
/ Installing yard hydrant #12
Mark
Gee Whiz. I looked at the posts before mine or I thought that I did. You said almost everything that I did. I need some new glasses.:confused:
/ Installing yard hydrant #13
I sure wish that were true here. My major front yard/drive hydrant is mechanically frozen shut. No shut off other than by turning off the pump and draining the system. It is also right under a big Birch so digging it out is/will be a royal pain. I have a "temporary" line run from the garden hydrant to a "temporary" hydrant wired to the frozen up one.
It appears to be due to corrosion between the actuating rod and the packing gland at the top. I have tried heat, beating with a hammer, etc. No luck.
Harry K
/ Installing yard hydrant #15
To help make sure the "drain field" around the bottom of the hydrant stayed open, I lined the holes on mine (6 of em) with landscape/weedblock/geotextile fabric, then dumped in about a foot of coarse gravel, then overlayed the top of that with more fabric. I firmly tamped all fill after about the first 6", and then every 6" after that, followed by a very firm tamping of the final/top layer. They all have about 18-24" of galvanized stem below grade, so with the gravel and tamped fill, they are quite solid with no re-bar or t-post support needed. I figure if one gets snagged by something, I'd rather have it wallow some and maybe be able to straighten and re-tamp it than to have it bend the riser and possibly break off.
- Jay
/ Installing yard hydrant #16
Paddy, yes this is the hydrant style I'm talking about. If the hydrant is on and water pressure drops below 20 psi water , bacteria can and does get in, also with water flow through hydrant contaminant can aspirate into the line, once it's in the line bacteria can grow contaminating the whole system. If the hydrant is open, and water is shut off at supply tank or city water is interrupted water can and does get siphoned back into the complete system.
/ Installing yard hydrant #17
A few links:
http://www.asse-plumbing.org/Articles/Backflow/Serious Cross Contamination in Yard Hydrants.pdf
Cross Connection and Backflow Prevention
Backflow, Backflow Prevention TechZone, cross connection control, backflow prevention, municipal backflow prevention, backflow preventer, fire sprinkler backflow prevention devices, industrial backflow prevention, united states department of defense backflow prevention requirements, military backflow prevention consultant, air force backflow prevention, department of the army backflow prevention, Navy Environmental and Preventive Medicine Unit backflow prevention requirements, residential backflow prevention, industrial cross connection control consultant, potable city drinking water safety, Michigan MDEQ, backflow prevention education or training, municipal water system, faucet hose bibb vacuum breaker, backflow preventer certification testing or tester, rpbp, municipal cross connection control program, cross connection surveys inspections, plumbing and mechanical engineering, backflow prevention news and articles, backflow, cross connection, cross-connection, plumbing history, backflow prevention history, cross connection control training, backflow rules, backflow regulations, cross connection control software, backflow software, preventer, devices, water contamination, water purity, safety, Ames, Watts, Febco, Hersey, Conbraco, Wilkins, Cla Valve, drinking water, Professional Backflow Prevention Association, American Backflow Prevention Association, PBPA, ABPA, Foundation for Cross-Connection Control and Hydraulic Research, FCCCHR, backflow prevention and cross connection control web log by Gerald Flis /TITLE>
Lawriter - OAC - Chapter 3745-95 Backflow Prevention and Cross-Connection Control
Backflow Hazards
http://www.purcellvilleva.com/documents/Sewer and Water/Cross-Connection Brochure.pdf
Youth Camps - Rule 410 IAC 6-7.2
Paddy, the last link is about Indiana, look under 410 IAC 6-7.2-25 (j)
/ Installing yard hydrant #18
suggestion: forget about the yard hydrant, and just bring up a piece of galv pipe and put a faucet on top of it: its cheaper, will feeze, but won't burst, unless you try to cover it up and miss a spot, or put a shut off in line: the shut off doesn't allow the water to be pushed back down the line when the faucet and pipe freezes: i put in at least 4 yard hydrants when i built in 86: replaced 3 of them at least once or twice, until i finally did this, and haven't had a single problem since.
heehaw
/ Installing yard hydrant #19
heehaw,
That may work in your location, but up North you will have a split line!
/ Installing yard hydrant #20
i first heard about this idea in Point Marion, Pa:thats pretty far north!! they freeze from the top down, which pushes the water back into the line: thats why they will split if a shutoff valve is used; "some brave souls" have even used sch 40 pvc and said they don't break, but i haven't got that brave yet.
heehaw
2018 Volvo VNL 760 T/A Sleeper Cab Truck Tractor (A61568)
2018 Volvo VNL 760...
2016 Ford Transit Van, VIN # 1FTYE1ZG8GKB07239 (A61165)
2016 Ford Transit...
2013 Komatsu WA320 Wheel Loader (A60352)
2013 Komatsu WA320...
UNUSED INDUSTRIAS AMERICA F08 HYD TILT LAND LEVELE (A62130)
UNUSED INDUSTRIAS...
Bobcat 435 FastTrack (A60462)
Bobcat 435...
UNUSED IRANCH MINI SEMI-AUTOMATIC QUICK CHANGER (A62131)
UNUSED IRANCH MINI...
