Installing rear remote, which position for the valves? L6060
/ Installing rear remote, which position for the valves? L6060 #1
billybonds
Bronze Member
Medford
New Holland Workmaster 35
I'm installing 2 rear remotes on my new Kubota L6060, and the instructions leave much to be desired. So I have 2 valves, a float detent and a double acting valve. Is there a standard or preferential position for each valve? 1 or 2?
/ Installing rear remote, which position for the valves? L6060 #2
Sort of depends on what you will be using the valves for.
Is there a specific use for these, or just to have sort of thing?
I personally would have the first valve the double acting and the 2nd valve with the float feature, but that is just me.
If you don't have anything specific in mind, probably won't make much of a difference one way or the other.
For now, just a hydraulic top link. The second was mostly just to have
2021 KUBOTA SVL75-2 SKID STEER (A60429)
2021 KUBOTA...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
BUNDLE OF 2"X2"X14' TUBING (A60430)
BUNDLE OF...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
2003 Sterling L9500 Series T/A Wet Kit Day Cab Truck Tractor (A59230)
2003 Sterling...
2023 FABRIQUE CARRY-ON -TILT 60"X8' TRAILER (A60430)
2023 FABRIQUE...
