Installing LED lights
/ Installing LED lights #1
varmint
Elite Member
Northern Maryland
Kubota B8200, then a Kubota L3130 HST, now a Kubota L3400 HST
A while ago, I wrote that I had ordered a pair of the 18W LED lights. I had thought originally about mounting them on the ROPS, but the idea of them being so close behind me, glaring, didn't seem desirable. I dug out some heavy wall rectangular steel tube, some bar stock, and played with my new little wire welder. I ordered a waterproof toggle switch and some waterproof connectors from China (cheap!) and of course, I needed some red 16 gage wire, and then some plastic wire tubing, the list goes on. I had an old 12V relay, which is probably overkill for a 3 amp load. I am very happy with the amount of light, and we'll see how well it works in falling snow, later this winter, no doubt. I used shrink tubing at the waterproof connectors, also overkill, I suppose. I also made the left light swivelable, mostly because I could? (sorry about the photo mess- I got distracted)
/ Installing LED lights #3
Lots of effort in that. Looks great!
Thanks for the encouragement. My wife lacks appreciation, and thinks the time would be better spent doing house improvements. Not fun, though.
/ Installing LED lights #6
My response to her?
"Honey, I can't do outside improvements this time of year without the lights. Its all about being safe. If I can't see, I may run over that flower bed you worked so hard to make it as beautiful as it is....just like you"
If that doesn't work, be quieter about tractor projects and act like its home improvement. Lol
/ Installing LED lights #9
VERY nice. I think it's a great job. Tidy plus the light placement looks to be dead on. Even painted it. Nice touch. Fit and finish can't get much better. It's a pass by a long shot. Enjoyed seeing it. Your going to be very happy with your new lights. :thumbsup:
Thanks for the kind words, Paul. Your seal of approval means a lot to us amatuers! Once your son's marriage is over, we hope to see some new projects from you. And, Pedalstomper, my wife has INDOOR stuff in mind. No tractors involved. Of course, when we get snowed in this winter, I will be sure to go out to plow at night!
Notforhire: Just looked at your installation- pretty much the same, indeed. Have you had them in use? I have been too busy to even take the tractor out at night to see them actually working. Lighting up the shop was fun, but didn't tell me that much, really, since even the headlights sort of did that.
/ Installing LED lights #12
I no longer own that tractor, but I had used the lights out on the road a couple of times. Our mount system was pretty much the same, but my lamps weren't LED. I used two Walmart auto driving lights. Because the regular headlights were useless with the loader, I disconnected them and powered the new lamps with the headlight circuit.
When I bought my Kubota I decided to mount 4/27 watt LED lights to the ROPS. I only picked this location because it was easier, not better. The LEDs provide plenty of light, and I was able to use the 10A work light circuit for all four lights. The LEDs don't reach as far as my Walmart lights, but at tractor speeds they are good enough. I do prefer the lights out in front of me. I wear glasses, and lights from the rear reflect off the back of the lens.
I may be installing a canopy and moving the lights forward.
Another advantage to your mount system is that it gives you a place to mount mirrors. Being a broken down old fart, I can't turn my head like an owl, so mirrors are nice if you have to travel on the road. If you look at my TC40 photo, notice the mirror on the left side.
I think you will be happy with your design and the amount of light provided by the LEDs.:thumbsup:
Best, Bill
Sounds good, Bill. I had clipped the lights on the ROPS, and hot-wired them, just to test that location. I was worried about hitting them with branches or whatever, but the glare from behind me convinced me not to bother with the ROPS. I spent too much time fussing with the installation, but if I keep the tractor another 10+ years, I suppose that time will be well spent. It's almost a 25 year old tractor, I think, but only has around 600 hours, and if I take care of it, and house it in the barn and not outside, hopefully it will last. It is used for snow clearing and the occasional fence post installation, maybe hauling some firewood from time to time, or helping neighbors pull or push something heavy. I keep waiting for something to fail, like the battery that's been in it for over 12 years, but so far...
/ Installing LED lights #14
Great job, varmit and Notforhire. 2 solutions in one thread. I have been pondering what to do about the glare on my glasses from the rops mounted led's, and also the best way to mount side mirrors as I, too, am a broken down old fart.
And that's why I like TBN.
HYDRAULIC BOBCAT UTV SNOW BLADE ATTACHMENT (A63569)
HYDRAULIC BOBCAT...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2016 Volkswagen Jetta Sedan (A61569)
2016 Volkswagen...
HEIN-WERNER 1TON TRANSMISSION JACK (A63569)
HEIN-WERNER 1TON...
ALLEN AR16 BUGGY (A63569)
ALLEN AR16 BUGGY...
Bad Boy Stand On Mower (A64047)
Bad Boy Stand On...
