Installing Hydraulic Top Link on B21
   / Installing Hydraulic Top Link on B21 #13
Excellent work by downsizingnow48. SurplusCenter.com has got plenty of my business. Good specifications and are quick to answer questions. Top quality hoses if you can use them.
Agricenter top link dimensions don’t specify min/max length as center of holes but probably are. Good question to ask them.
The 3pt hitch is bigger on my B26 than my old B20 with higher lift capacity. Pat’s quick hitch also requires longer top link length.
Never cared for turnbuckle sway control or side link adjuster. So if in the fabrication mode make some telescoping sway bars. Together with Pat’s makes changing implements easy. IMG_0669.JPG
55-Gallon Drum of 50/50 Antifreeze Star Fire Pure Fleet Red Heavy Duty (UNOPENED) (A59076)
55-Gallon Drum of...
2007 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A58214)
2007 INTERNATIONAL...
2015 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 567...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
Deere 325G (A57148)
Deere 325G (A57148)
