Installing Gauges on B3030 with cab
   / Installing Gauges on B3030 with cab #1
ficord
USA
Kubota
I didn't like the plain plastic panel above the factory gauges so I added a clock oil pressure and volt meter to fill the void on the factory panel, I moved the wiper and work light switches to either side like on a car. I tried to made it look factory by using a 3/4 in abs plastic board I used a heat gun to duplicate the finish on the original panel. Now I'm wondering if its too much. A new panel is 12.00 if I want to put it back the way it was. I figured I'd try it if it didn't work out i would just buy another panel.
http://img.auctiva.com/imgdata/6/0/8/2/4/5/webimg/100587627_o.jpg
http://img.auctiva.com/imgdata/6/0/8/2/4/5/webimg/100590838_o.jpg
http://img.auctiva.com/imgdata/6/0/8/2/4/5/webimg/100587642_o.jpg
http://img.auctiva.com/imgdata/6/0/8/2/4/5/webimg/100587690_o.jpg
http://img.auctiva.com/imgdata/6/0/8/2/4/5/webimg/100587674_o.jpg
http://img.auctiva.com/imgdata/6/0/8/2/4/5/webimg/100587663_o.jpg
You posted great pictures of your 3030 smfcpacfp, it looks so good out there in the snow.
Isn't it just a great tractor I couldn't be more pleased with mine.
   / Installing Gauges on B3030 with cab #4
It looks factory to me. Excellent job.
The heat gun technique sounds interesting to add texture to the plastic. You could also look for hair-cell ABS, which has a texture similar to what automotive plastics have. The term hair-cell is what the plastics supplier I buy from calls the stuff.
   / Installing Gauges on B3030 with cab #5
I agree it is a great tractor. Where did you get the gauges? the material to make the case? Did you just cut the center out of the piece of plastic that held the switches? Did you take a few other "in process" pictures? I really like what you did and would mind replicating it.
I got the Gauges from JEGS they shipped out the same day , very good service.
I'll send you and email and explain everything on how to make it.
   / Installing Gauges on B3030 with cab #7
Wow, what a nice looking job! I can't imagine why you'd want to undo it. Thanks for posting the pictures.
   / Installing Gauges on B3030 with cab #8
Watch out Kubota will be taking your lead and offering the panel & gages as an option. Wait and see!
What's nice about this panel is that it fits right over the factory panel using the same two mounting holes. Why wait for Kubota. I'll take orders for the panels - you guys pick your own favorite gauges and install them in the pre made panel.
But I'm only limited to the first 8,000 orders.
HOPKINS 40 TRI-AXLE DATA VAN TRAILER (A50854)
HOPKINS 40...
19008 (A48082)
19008 (A48082)
2005 LUFKIN 48X102 SPREAD AXLE FLATBED (A50854)
2005 LUFKIN 48X102...
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A51039)
Heavy-Duty...
2017 Ford F-550 Bucket Truck - 4x4, Powerstroke Diesel, Versalift VST47, 52FT Reach (A51039)
2017 Ford F-550...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A49461)
1993 Ingersoll...
