Installing ford 4400 pto shaft.
/ Installing ford 4400 pto shaft. #1
paintma1
FORD 4400 3CYL DIESEL
I was bushoging yesterday and noticed my pto shaft was not spinning. I looked where the shaft entered the housing and fluid was pouring out. The shaft had slid out about 6 inches and destroyed the bearing. After removing the drive shaft for the bushog I pulled on the pto shaft and it pulled completely out of the housing. Am I going to have a large problem putting the shaft back in? There is a c clip ring on the shaft and there was a very fine spring partly under the c clip.Any advice would be greatly appreciated. Thanks
/ Installing ford 4400 pto shaft. #2
You ever get an answer on this? I had the very same thing happen today. Cutting/cutter stopped/ pot shaft was further out than usual/gushing fluids. I got it back to the house and when I pulled the cutter link, the whole shaft came out. It looks great, but wondering if I broke a seal, or a bearing right at the end if the housing. Planning to pull the back plate off tomorrow and see what I find.
I'm on a '65 Ford 4000 8 speed
Landhero Backpack Leaf Blower (A66408)
Landhero Backpack...
2022 EZ-GO ELITE...
Metal Toolboxes (A65583)
Metal Toolboxes...
Case 2090 Tractor (A66285)
Case 2090 Tractor...
Ford 8N Tractor (A66408)
Ford 8N Tractor...
2007 Kia Amanti (A66408)
2007 Kia Amanti...
