installed trac-vac
/ installed trac-vac #1
vic654
Rhode Island
John Deere 3720
i finally got around to installing the trac vac i had on my old kubota BX.It was pretty easy retro fit i had to buy a new boot to fit the mower deck and bought a new half of pto so it would fit my distance on new tractor.
Is was a lot easier than i thought only took about an hour once i had the materials.Heres a couple pics of the setup
/ installed trac-vac #2
Very Nice! I have about the same set up on my JD2210. Is the Trac-Vac for the 540 speed PTO or the Higher one. Trac-Vac makes a model 856 that supposed to run on a Kubota and the PTO speed is 850 RPM's. This is the unit I have on mine and while it is running a little slow on my 2210 it seems to pulling enough to vacuum anything that comes along. Would like to boost the speed of my blower a little if I could figure out a way.
/ installed trac-vac #3
That's mowing in comfort! Nice setup. If you can fab a hose hanger to hold the vacuum hose off the ground and away from the rear tire I think the vacuum hose would last a lot longer.
Super-duper setup!
Don
The bx runs at 540. i have the 854bx tracvac which runs also at 540 and works at full power on ny 3720
/ installed trac-vac #5
I know this is an old thread, but I came across it while searching...
That is one nice setup! :thumbsup: I was wondering if anyone else used a TracVac with a similar sized tractor?
/ installed trac-vac #6
I had one on my 770 but the 3pt mounting was Mickey mouse. I had to take the lift links off, use the trac vac ones and fudge up the mower mounts. I had it for about 15 years and it was 1/2 worn out so I sold it and bought the one that runs off a 8 hp motor. Pop a pin and disconnect the hose and the unit is off. It is easier to rake into the trac vac around the bushed as you don't need to bypass the safety switch on the pto.you don't even need it hooked to the tractor. Trac Vac is a great machine. I bet I've dumped over 100 full loads over the years.
/ installed trac-vac #7
I know this is old, but,
You could change out the pulleys and belts to increase rpm. Either increase the pulley size on the driven pulley, or reduce the impeller pulley.
Does you tractor have two PTO speeds?
CADMAN 4500 WIDE BODY HARD HOSE TRAVELER (A63291)
CADMAN 4500 WIDE...
2022 EZ-GO ELITE...
JLG TELESCOPIC FORKLIFT (A64279)
JLG TELESCOPIC...
2019 FREIGHTLINER CASCADIA CA113DC 6X4 T/A DAY CAB TRUCK TRACTOR (A59911)
2019 FREIGHTLINER...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A59823)
2015 FORD F-150...
Mercury Verado 350HP 4 Stroke Boat Motor (A61574)
Mercury Verado...
