Inspection Heads Up
/ Inspection Heads Up #1
NC419N
Kubota BX2670 Kioti NX5510C Ford 3000 ford 4500TLB Ford 9N Farmtrac 555DTC New Holland 1720 New Holland 2120 Kubota BX22 Kubota ZD1200
Before heading out to clear the snow Saturday checking the fluids and such I noticed a small section of the fan blade on the NX chipped out. Thought it looked strange and then found a relay block dangling down it the path ???? That was a little un-nerving with a little less than 50 hours of use. What I found was the bolts that were originally holding it on had worked their way off and the relays on the opposite side were laying on the radiator. Guessing they don't use nylon lock nuts??? Fortunate for me to have m6 x 1 hex nuts and blue Loctite !!! You may want to Inspect any and all bolts that you can to insure tightness and invest in Loctite products before large on small parts vibrate off of you equipment.
/ Inspection Heads Up #2
Wow, could have been a lot more damage. Wires ripped out are not a good thing.
Glad you found it early.
2016 FORD E450 SHUTTLE BUS (A59914)
2016 FORD E450...
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
2001 Ford F-450 Super Duty Flatbed  7.3L Power Stroke Diesel (A63689)
2001 Ford F-450...
Land honor Mini Skid Steer (A60352)
Land honor Mini...
TOP HAT 5' X 13' S/A TRAILER (A64277)
TOP HAT 5' X 13'...
