Input needed on Bolt on shackle mounts for the FEL bucket
   / Input needed on Bolt on shackle mounts for the FEL bucket #11
Kenny, those look like a good quality product and I was going to buy those.the only draw back was,you dont offer the backing plates.Is there any chance you will be offering them in the future?
Possibly, but I have have a good explanation on the FAQ page on why I don't think they are needed.
I just installed these on my 2310 today.I have not tried them out yet though. (raining again).
I also bought the backing plates.
I am to hear somebody else had the same idea.
When you get a chance to use them, please let me know what you think.
Thanks for the pics too. :thumbsup:
   / Input needed on Bolt on shackle mounts for the FEL bucket #13
Will do !!!!!! :thumbsup:
   / Input needed on Bolt on shackle mounts for the FEL bucket #14
I would;
a) Use them with the backing plates - though I would use somewhat larger backing plates if material was available and I had the tools.
I would make them as long as possible in the up/down direction, wouldn't worry that much about the left/right direction.
b) Mount them as close to in line with the bucket cylinders as practical.
c) Use the biggest anchor shackles (probably 3/4 inch) that I could fit in them.
d) Step down to 3/8 chain hooks, perhaps via a smaller anchor shackle.
This is one of the nice things about NOT having welded on chain hooks, you can go to any/every size chain hook via anchor shackles.
I switch between 3/8 and 1/4 inch chain a lot and it is HANDY to put 1/4 inch chain in a hook and not have it jam because the hook is too big.
Did you get a chance to try them out yet?
   / Input needed on Bolt on shackle mounts for the FEL bucket #17
Man those bolt on grab hooks are expensive. I would think a local welder could fab up a couple of those for half that.
   / Input needed on Bolt on shackle mounts for the FEL bucket #18
chooligin: I would weld a length of 2" schedule 40 pipe under the lip of the leading edge of that bucket before you bend the edge up lifting with chains. Its a pretty easy fix now before its all bent up, just get yourself 6' of pipe and stich weld it in.
Utility Trailer (A52377)
Utility Trailer...
2009 KENWORTH T800 DAY CAB FLAT TOP ROAD TRACTOR (A57192)
2009 KENWORTH T800...
JCB 2145 (A47477)
JCB 2145 (A47477)
34" EXCAVATOR BUCKET (A57192)
34" EXCAVATOR...
UNUSED FUTURE FT-CW59 59" HYD COMPACTION WHEEL (A57193)
UNUSED FUTURE...
2018 Ford Escape SE AWD SUV (A55853)
2018 Ford Escape...
