Input needed on Bolt on shackle mounts for the FEL bucket
   / Input needed on Bolt on shackle mounts for the FEL bucket #11
Kenny, those look like a good quality product and I was going to buy those.the only draw back was,you dont offer the backing plates.Is there any chance you will be offering them in the future?
Possibly, but I have have a good explanation on the FAQ page on why I don't think they are needed.
I just installed these on my 2310 today.I have not tried them out yet though. (raining again).
I also bought the backing plates.
I am to hear somebody else had the same idea.
When you get a chance to use them, please let me know what you think.
Thanks for the pics too. :thumbsup:
   / Input needed on Bolt on shackle mounts for the FEL bucket #13
Will do !!!!!! :thumbsup:
   / Input needed on Bolt on shackle mounts for the FEL bucket #14
I would;
a) Use them with the backing plates - though I would use somewhat larger backing plates if material was available and I had the tools.
I would make them as long as possible in the up/down direction, wouldn't worry that much about the left/right direction.
b) Mount them as close to in line with the bucket cylinders as practical.
c) Use the biggest anchor shackles (probably 3/4 inch) that I could fit in them.
d) Step down to 3/8 chain hooks, perhaps via a smaller anchor shackle.
This is one of the nice things about NOT having welded on chain hooks, you can go to any/every size chain hook via anchor shackles.
I switch between 3/8 and 1/4 inch chain a lot and it is HANDY to put 1/4 inch chain in a hook and not have it jam because the hook is too big.
Did you get a chance to try them out yet?
   / Input needed on Bolt on shackle mounts for the FEL bucket #17
Man those bolt on grab hooks are expensive. I would think a local welder could fab up a couple of those for half that.
   / Input needed on Bolt on shackle mounts for the FEL bucket #18
chooligin: I would weld a length of 2" schedule 40 pipe under the lip of the leading edge of that bucket before you bend the edge up lifting with chains. Its a pretty easy fix now before its all bent up, just get yourself 6' of pipe and stich weld it in.
IRanch Dump Hopper (A55851)
IRanch Dump Hopper...
24ft T/A Flatbed Trailer (A55787)
24ft T/A Flatbed...
UNUSED RAYTREE RMBD72 72" HYD DRUM MULCHER (A57193)
UNUSED RAYTREE...
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
UNUSED FUTURE X.HW672 72" HYD HOLLOW WOOD GRABBER (A57193)
UNUSED FUTURE...
