Inner Tube material quality
/ Inner Tube material quality #1
bjr
Veteran Member
Eastern WA
Jinma JM354
I've seen inner tubes seem to rot prematurely, has the rubber change lately or am I just getting some real junk from the tire vendors. A friend left a small brand new tube outside on a bench for less than a month and had to throw it away 'cause it was rotten. The last one I had to pull was only two years old and the stem came out and it was on a small trailer. bjr
/ Inner Tube material quality #2
First off, rubber inner tubes are mostly some type of plastic.
I also had problems with small imported tubless tires so I added inner tubes.
With tubes the tires leaked just as fast as without.
As a result I have some 3-4 carts that are always flat when I need to use them.
Quality is sure not what it used to be but prices always go upwards while quality goes the other way.
/ Inner Tube material quality #3
Theyre making inner tubes smaller now so they have to stretch more. Sometimes they get thin as a rubber. Ive had them pop when just back from the tire shop from a grain of sand in the tire.
larry
/ Inner Tube material quality #4
They are making tubes with far less natural rubber, mostly synthetics. That is why all my lawnmowers, low speed trailers, wheel borrow are all filled with tire slime and not just a little, I pump them full. No more grabbing the air tank everytime I want to use one.
2019 Autocar Xpeditor Garbage Truck (A62613)
2019 Autocar...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
240 Massey Ferguson Tractor (A61165)
240 Massey...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2018 FREIGHTLINER...
(INOP) JOHN DEERE 694 CORN HEAD (A63291)
(INOP) JOHN DEERE...
2017 Ford F-150 Pickup Truck (A61573)
2017 Ford F-150...
