inner tube for tire
   / inner tube for tire #1
washita
south western michigan
pt 425, JI Case, Gravely Comm.10A
can any member recommend a good quality inner tube manufacture, ripped a gaping hole in a front tire while roto tilling today, it was more than ''slime'' could handle to fix that hole
   / inner tube for tire #2
I just go to the tire store and have them tube it, but it is a PITA, lots of complaining because the valve stems are not in conventional position on the 1850.
   / inner tube for tire #3
Have you considered foam tires? No flats, ever.
actually I have considered foam filling the tires unfortunately no one local handles the semi-firm type of foam , until the rear axle replacement is done on my truck I am unable to haul anything at the moment , but foam filled tires will be an option in the near future, I deal with a lot of black locust trees and multi-flower rose when clearing/reclaiming land and both are hard on tires, locally most guys use ''slime'' or equivalent for agriculture use. I could upgrade to a 8ply skid steer type tire, but then I would have to order rims to fit, I think scouring the surplus center's might net something I could use
   / inner tube for tire #5
I did the same to one of my tires and I am sad to say i was never happy untill i just bought another tire and slimed it. You just dont slime or plug a tire with a tube in it. Good luck though.
   / inner tube for tire #6
This isn't quit the same, but i slimed the tube that i put in my rough cut mower tire, it worked well as far as keeping air in it.
2003 Ferris IS1000 52in Zero Turn Mower (A51694)
2003 Ferris IS1000...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2013 Audi Q7 AWD SUV (A51694)
2013 Audi Q7 AWD...
2012 VOLVO ECR305CL EXCAVATOR (A51246)
2012 VOLVO...
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
1990 WhiteGMC Autocar ACL64 Dump Truck, VIN # 4V2SCBME1LU505122 (A51572)
1990 WhiteGMC...
