Inner Lower adjustable arm linkage Parts availability linkage?
   / Inner Lower adjustable arm linkage Parts availability linkage? #11
See if you can fit the ones off a 50 series they are beefier.
   / Inner Lower adjustable arm linkage Parts availability linkage? #12
Not to get off the subject.. But what is that quick disconnect in the picture? It looks like its plummer into the rear end?
   / Inner Lower adjustable arm linkage Parts availability linkage? #13
Raising before you turn? Never considered that you need too. Sure enough I have not been. The plots I'm working are big enough that I was just going round and round to the middle.
I'm pretty sure pushing piles of stuff backwards with the box blade contributed, even then I was backing and turning.
Bet yer bippie I'll be lifting from now on! I'm a 100% noob so take the lessons as that come I guess.
Turning without picking up a 3 pt. Implement would get me yelled at real quick when I was a kid. Had that pounded in my head.. good way to break off disk blades too. My disk has two disc broke off now from my son in law, I know I told him more than once, but think he wasn't hearing..
That is the return for the Backhoe, I did blow it out and put the cover back in.
   / Inner Lower adjustable arm linkage Parts availability linkage? #15
I learned the hard way on this also. I now have 2 broke disks off an old 8ft MF. I didnt bend the stabilizers doing that. I bent one using my box blade to knock over 6-10 inch diameter apple trees. I was using a 54 super M with a cat 2 three point bolted on the back. After buying a replacement at TSC, I decided to use my head for something other than a hat rack...
   / Inner Lower adjustable arm linkage Parts availability linkage? #16
I you want to disc in circles get a drag disk, in my experience they usually cut the ground a lot better any way. Can be hard to transport though. For some reason I can't understand. the highway dept in MO doesn't like you pulling them down the highway...........
   / Inner Lower adjustable arm linkage Parts availability linkage? #17
These folks can get you the part...and they have the manuals posted so you can look up the part number.
Parts for LS Tractors
Those folks is where I got the part number in my first post and official name in my first post.
Having manuals and actual access to the parts in those manuals are different critters. I appreciate that he is hosting them and making them available on the interwebs, it is just that there are no parts out there for the XR series as far as my searches have found.
That is why I posted here at TBN, there are literally thousands of eyes reading these posts and chances are very good that someone here will know if an earlier year would work.
   / Inner Lower adjustable arm linkage Parts availability linkage? #19
You never said any of that in your first post. You also haven't said if you called them or not...have you? All or most of their parts are shipped from the LS distributor in NC.
   / Inner Lower adjustable arm linkage Parts availability linkage? #20
Was the other side tight when you bent that? What I normally do is:
1. Pin up one side of the sway reducer
2. Slide that sidelink as far onto the sidelink pin as it will go
3. Push the other sidelink as far onto the sidelink pin as it will go
4. Pull the implement away from the side that it pinned
5. Pull the unpinned sway adjuster tight and then pin it
6. Push the implement from side to side to see if it will sway.
7. If it sways more than 1" I repin the sway reducers tighter.
It looks like yours was very loose to have enough play in the other side to let it bend that much.
Aaron Z
Husqvarna Riding mower (A56857)
Husqvarna Riding...
2010 Honda CR-V SUV (A55853)
2010 Honda CR-V...
2018 TowMaster T-12D T/A Flatbed Trailer (A55853)
2018 TowMaster...
White Metal Roof Panels (A55758)
White Metal Roof...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
