Injectors for a B7200
/ Injectors for a B7200 #1
CalG
Super Member
vermont
Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
D950 engine IIRC.
Are there "Monarch" injectors available? I'm doing a web search now.
This tractor has set too long. It runs, but blows white smoke. I would like to illiminate fouled injectors from the problems.
I could have these originals serviced, but I read good things about the Monarks....
/ Injectors for a B7200 #2
The advantage to having the injectors serviced rather than replaced is that you get to find out if they were not spraying properly and on which cylinder(s).
Replace them all and still have a problem then where are you?
Just my preference.
Dave M7040
/ Injectors for a B7200 #3
When you are having fuel feed problems have Both the Injector Pump And the Injectors serviced, cleaned and inspected... you will have a much better complete system and it should be the most economical approach... KennyV
If you want a recommendation for a great shop... Badger Diesel in Union Grove WI. Fred is a great guy, and very honest.
New/Unused 3-in-1 Quick Attach Frame (A65583)
New/Unused 3-in-1...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
New/Unused Landhonor Hand Chain Lever Hoist (A65583)
New/Unused...
CASE 580N BACKHOE (A65053)
CASE 580N BACKHOE...
2015 DODGE MINI VAN (A63290)
2015 DODGE MINI...
