injector washers
/ injector washers #1
tmar04
YM 276
can anyone tell me how many and type of washers that go at base of injector body, down in the head opening, on yanmar ym2500. nylon, copper,etc. I am replacing the nozzle valve and body in my three injectors, and there was only one nylon sealing washer at base of inj body. thx to all.
/ injector washers
come on, now. surely someone out there has removed inj and replaced nozzle body. anyone--------------?
/ injector washers #3
Yeh, but not in a Yanny. Have you posted on the yanmar forum?
jb
/ injector washers #4
Most will have copper where the injector meets the head. Ones i used to work on had aluminum wrapped around fiber material. Hard to explain.
Never seen a nylon seal there.
Good Luck,
Rob
/ injector washers #5
I have removed the injectors from my Yanmar YM1700. If i remember correctly there is a copper washer between the 2 halves of the pre-combustion chamber and a copper washer on the top half then there is a fiber type of washer on that. I am not sure of the composition of that but, I bought new ones. The old ones probably would not have sealed anymore.
You would probably get more response if you post your question in the Yanmar Forum.
2015 Ford F-150 Ext. Cab Pickup Truck (A66736)
2015 Ford F-150...
2020 FREIGHTLINER M2 106 WATER TRUCK (A67714)
2020 FREIGHTLINER...
2023 CRUISER RV SHADOW CRUISER (A67714)
2023 CRUISER RV...
2005 MACK CHN613 (A67714)
2005 MACK CHN613...
2025 Kubota RTV520 4x4 Gas Utility Cart (A66734)
2025 Kubota RTV520...
2003 BOBCAT 331D EXCAVATOR (A65056)
2003 BOBCAT 331D...
