injector washers
/ injector washers #1
tmar04
YM 276
can anyone tell me how many and type of washers that go at base of injector body, down in the head opening, on yanmar ym2500. nylon, copper,etc. I am replacing the nozzle valve and body in my three injectors, and there was only one nylon sealing washer at base of inj body. thx to all.
/ injector washers
come on, now. surely someone out there has removed inj and replaced nozzle body. anyone--------------?
/ injector washers #3
Yeh, but not in a Yanny. Have you posted on the yanmar forum?
jb
/ injector washers #4
Most will have copper where the injector meets the head. Ones i used to work on had aluminum wrapped around fiber material. Hard to explain.
Never seen a nylon seal there.
Good Luck,
Rob
/ injector washers #5
I have removed the injectors from my Yanmar YM1700. If i remember correctly there is a copper washer between the 2 halves of the pre-combustion chamber and a copper washer on the top half then there is a fiber type of washer on that. I am not sure of the composition of that but, I bought new ones. The old ones probably would not have sealed anymore.
You would probably get more response if you post your question in the Yanmar Forum.
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
2006 GODWIN GHP45KW-RC 45 KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
Ripper Tooth Excavator Attachment (A61567)
Ripper Tooth...
Brent 420 Grain Cart (A63118)
Brent 420 Grain...
2022 Bobcat T66 R - Series Skid Steer (A61166)
2022 Bobcat T66 R...
