Injector seals/compression washers
/ Injector seals/compression washers #1
VonKasta
Iseki
So Im rebuilding an old Iseki ts2220 I bought for cheap, it is fitted with a Isuzu 2ab1 2-cyl diesel engine.
It has been fired up successfully but as it was running I noticed a kompression leak around an injrctor.
Pulled the injectors and foun two bad and two missing washers. I have sourced new nozzle washers as I suppose they are the kompression seals. But the ones called corrugate washer wasnt there.
I have measured the space and calculated the thickness and with, but how are they supposed to look?
Can I use a solid kopper washer of the correct size or are they meant to collapse on itself as you tighten the injector like a washer on a spark plug?
Finally found a picture of one, for future reference.
/ Injector seals/compression washers #3
Your picture didn't come across. If you choose to use a copper washer, heat it first until it's red hot then allow it to air cool. This should allow it to act as a seal. Your injectors are probably Nippon Denso and as such any shop working on diesel injectors should be able to supply the correct washers - or even overhaul yours if necessary.
Ive found Bosch no 2430190002 to be the same dimentions as the washer I am looking for, nozzle heat shield in older Bmw diesels amongst others.
6'4" X 10' S/A TRAILER (A64277)
6'4" X 10' S/A...
Landhonor SAD-12-23C Skid Steer Mount Auger (A62679)
Landhonor...
2022 EZ-GO ELITE...
40' One-Trip Shipping Container (A66285)
40' One-Trip...
School bus (A64194)
School bus (A64194)
Dueling Tree (A65640)
