Injector seals/compression washers
/ Injector seals/compression washers #1
VonKasta
Iseki
So Im rebuilding an old Iseki ts2220 I bought for cheap, it is fitted with a Isuzu 2ab1 2-cyl diesel engine.
It has been fired up successfully but as it was running I noticed a kompression leak around an injrctor.
Pulled the injectors and foun two bad and two missing washers. I have sourced new nozzle washers as I suppose they are the kompression seals. But the ones called corrugate washer wasnt there.
I have measured the space and calculated the thickness and with, but how are they supposed to look?
Can I use a solid kopper washer of the correct size or are they meant to collapse on itself as you tighten the injector like a washer on a spark plug?
Finally found a picture of one, for future reference.
/ Injector seals/compression washers #3
Your picture didn't come across. If you choose to use a copper washer, heat it first until it's red hot then allow it to air cool. This should allow it to act as a seal. Your injectors are probably Nippon Denso and as such any shop working on diesel injectors should be able to supply the correct washers - or even overhaul yours if necessary.
Ive found Bosch no 2430190002 to be the same dimentions as the washer I am looking for, nozzle heat shield in older Bmw diesels amongst others.
RoadTec RP190 (A63689)
KBH Tender Trailer (A63688)
KBH Tender Trailer...
20in Single Cylinder Grapple Bucket Skid Steer Attachment (A61572)
20in Single...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2018 FREIGHTLINER...
HARDEE 200 GALLON POLY TANK SPRAYER, 3PT (A63291)
HARDEE 200 GALLON...
2006 CHEVROLET EXPRESS 4X2 SERVICE BOX TRUCK (A59911)
2006 CHEVROLET...
