Injector pump question
/ Injector pump question #1
bikemiser
East Central Illinois
Kubota BX1830
I was just wondering if the injector pump on a BX has oil in it to be checked or changed. I don't remember seeing anything about that in the book.
/ Injector pump question #3
There is nothing in the book about that type of maintenance on the pump.
/ Injector pump question #4
/ Injector pump question #5
Bike for short... there is no maintenance you can perform on your injection pump. I wouldn't touch it if you are a homeowner anyway for two years during the warranty period. If your injection seems weak, only notice by a loss of power under load, I would check the filters and fuel deliver from your lift pump first. After warranty, take it to a fuel shop where it can be rebuilt, calibrated and bench tested professionally. Good post! /forums/images/graemlins/wink.gif
/ Injector pump question #6
Thanks for info. So I guess any oil or grease is sealed inside never to be to be messed with. /forums/images/graemlins/smile.gif
/ Injector pump question #9
I could be wrong here, but I believe the injector pump is lubricated by the fuel itself.
/ Injector pump question #10
/ Injector pump question #11
You are not wrong. The best thing for the injection pump is good clean fuel. It'll outlast your motor.
Let me check that oil comment, some pumps do have motor oil lubrication. It comes in the side and flows through the front drive bearing (usually). But the business end is diesel, and that's where the cleaner the fuel the better.
/ Injector pump question #12
Deutz Engine Manuals (A63117)
Deutz Engine...
2000 Sakai SV505 (A64119)
2000 Sakai SV505...
2018 Freightliner M2 106 Cab and Chassis Truck (A59230)
2018 Freightliner...
2020 John Deere 560R Premium Round Baler (A63111)
2020 John Deere...
2016 Eager Beaver 20XPT 27ft 24 Ton T/A Tag Trailer (A61573)
2016 Eager Beaver...
2014 Freightliner Coranado 132 Daycab (A62679)
2014 Freightliner...
