Injector pump question
/ Injector pump question #1
bikemiser
Bronze Member
East Central Illinois
Kubota BX1830
I was just wondering if the injector pump on a BX has oil in it to be checked or changed. I don't remember seeing anything about that in the book.
/ Injector pump question #3
There is nothing in the book about that type of maintenance on the pump.
/ Injector pump question #4
/ Injector pump question #5
Bike for short... there is no maintenance you can perform on your injection pump. I wouldn't touch it if you are a homeowner anyway for two years during the warranty period. If your injection seems weak, only notice by a loss of power under load, I would check the filters and fuel deliver from your lift pump first. After warranty, take it to a fuel shop where it can be rebuilt, calibrated and bench tested professionally. Good post! /forums/images/graemlins/wink.gif
/ Injector pump question #6
Thanks for info. So I guess any oil or grease is sealed inside never to be to be messed with. /forums/images/graemlins/smile.gif
/ Injector pump question #9
I could be wrong here, but I believe the injector pump is lubricated by the fuel itself.
/ Injector pump question #10
/ Injector pump question #11
You are not wrong. The best thing for the injection pump is good clean fuel. It'll outlast your motor.
Let me check that oil comment, some pumps do have motor oil lubrication. It comes in the side and flows through the front drive bearing (usually). But the business end is diesel, and that's where the cleaner the fuel the better.
/ Injector pump question #12
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A59228)
2015 Chevrolet...
2011 John Deere 9770 (A64119)
2011 John Deere...
2021 DITCH WITCH HX30 TOWABLE VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2012 FREIGHTLINER CASCADIA 125 6X4 T/ANDEM  SLEEPER TRUCK TRACTOR (A59911)
2012 FREIGHTLINER...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
