Injector problem?
/ Injector problem? #2
Tractor won't start.
Tractors rpm wants to run away.
/ Injector problem? #3
You would have a miss, the same as as a shorted spark plug in a gas engine. Check by loosening each injector line while the engine is running, the same as removing each spark plug wire on gas. Hope this helps. Ron.
/ Injector problem?
TractorLegend said:
It just begs the question---why do you ask??
Because that was the over the phone diagnosis of the problem. Engine started clattering away, lost almost all power. Was entertaining getting it on the trailer to go to get fixed. Not convinced myself, but Kioti pays for what ever it is.
Tractor would start, no runaway, never heard a miss like that. No experience with diesel problems, so I dunno. 100 hrs.
/ Injector problem?
Broken valve, #1 cylinder, tractor was delivered but I wont see it for a couple of weeks, hope it is fixed. Kioti pays the bill, except for pickup and delivery.
/ Injector problem? #7
Sorry to hear that it broke, but at least they are going to fix it. How far away are they? Maybe yours is just an isolated case.
22" PIN-ON EXCAVATOR BUCKET W/PINS (A60429)
22" PIN-ON...
KBH Tender Trailer (A63688)
KBH Tender Trailer...
TARTER 180 CATTLE SWEEP (A64277)
TARTER 180 CATTLE...
Deutz F3L914 3-Cylinder Air-Cooled Diesel Engine - 54 HP - Pump Takeout (A63689)
Deutz F3L914...
6 1/4 INCH OD 90 DEGREE ELBOWS (A65643)
6 1/4 INCH OD 90...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
