Injector issue
/ Injector issue #1
ch1ch2
Veteran Member
DFW, TX
IH 584, NH TC33DA, NH TN95A
I changed the fuel filter. Tried to run the tractor. It died. It took a long time to get it bleed of air. I cracked open the injectors, open them some more and some more. Finally got it to flowing fuel. Got it to run but it was ruff. It lacked power, so I went back to bleed the injectors. Cracking open #1, fuel comes out. Cracking open #2, fuel sprays every where. Cracking open #3, just gets an air bubble every now and then. (this is with engine running.)
What has gone wrong? Why is #3 not injecting fuel?
Tractor is a NH TC33D
/ Injector issue #2
You aren't real clear...
Was everything going fine and you changed the filter or was there a problem and you changed the filter?
Either way, try cracking #3 at the pump and see what happens.
/ Injector issue
Everything was fine. Changed the filter.
I thought about cracking at the pump but I did not see how it would make a difference. I can give it a try.
It took a long time to prime the air out. I am concerned that the lack of fuel in the pump may have damaged the pump. Does that happen?
/ Injector issue #4
I don't know that cracking a line at the pump will do a thing, but that'd be my next step.
Filters get changed all the time with extended cranking before restarting. I wouldn't worry.
2009 Chevrolet Tahoe SUV (A64557)
2009 Chevrolet...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
2018 Ford F-150 4X4 (A62679)
2018 Ford F-150...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
2023 JOHN DEERE 550P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
