Injection timing
/ Injection timing #1
k4330
poconos pa
Kubota 5030 hst
I have a jd 330 with a yanmar in it that I picked up. The prior owner put new injectors and glow plugs in it. It does not run good, I want to check the timing but don't know how.. Thanks
/ Injection timing #2
The timing is set w/ steel shims under the injection pump & normally doesn't "just change"..
Its pretty involved, so you better get a book.. and a torque wrench.
What is> "doesn't run good" mean? slow acceleration? skip or miss? doesn't start quick enough?
/ Injection timing
When I picked it up it seemed it was running on 2 cyl's and smoking. Got it home, Tried to bleed the injectors, pulled them out and now it is hard to get it going, It will almost start but won't..
/ Injection timing #4
If the injectors are new & its running on about 2 cylinders & is hard to start,
the problem is either the injection pump itself.. feed pressure going TO the inj. pump if it has a lift pump..
Or it may be a restriction in the line from the fuel tank up to the inj. pump..
I would disconnect the line AT the inj. pump, take off the fuel tank cap & blow back thru the line TO the tank & listen for bubbles.
MAKE SURE the shut off valve is OPEN, if you have one..
You'll prob. get a real good stream of fuel coming back out atcha so be alert..
Hook the line back up & loosen the lines AT the injectors..
With the THROTTLE IN THE WIDE OPEN/FULL THROTTLE POSITION..crank the engine until fuel squirts out w/ no air & tighten..
It should "bust off" then.. Let us know what happened..
/ Injection timing #5
Did you buy it w/ this problem?? & that's why the guy sold it??
/ Injection timing #6
If you google JD 332, on utube, theres a vid of a fella getting his going.. how to bleed the fuel system.
What to look for on the filter, what screws to turn to bleed the air & such.. hope this helps.
/ Injection timing
I have plenty of fuel from the electric pump and none of the hoses are restricted. I will try to bleed the injectors with the throttle open, I did not do that. Yes I bought it this way.. Thanks
/ Injection timing #8
Right. As the pump guy says. Dollars to donuts says your problem is somewhere between the fuel tank and the injectors. And it sounds like something so simple that it is easy to overlook. Either something is blocking fuel through the lines, or some joint is leaking air into the lines. If it ran on 2 cylinders recently it probably isn't the high pressure fuel pump. Don't go there yet. If you do go there, first thing is to measure the pressure at the injectors and at the pump.
You want to leave changing injector timing to the very last. Way last. For one thing, it can't really change unless it is messed with. Injector timing should last unchanged for the life of the injector pump, and often for the life of the tractor. For another, injector timing isn't hard to understand, but it is real picky work. The sort of thing that mechanics prefer to do in a clean shop with all the right tools which includes things like degree wheels, dial indicators, pressure gauges, and very exact shims measured in thousandths of an inch. Otherwise you just end up guessing at it.
YMMV, rScotty
/ Injection timing #9
They wont run very well on 2 cylinders, if at all..
Loosen the steel lines up AT the injectors.. actually, take them completely loose..& pull them away from the injectors SLIGHTLY.
Now crank the engine.. what do the squirts look like.. only 2.?? All 3.?? 2 strong & 1 dribble.??
So lets pause a sec.. You have GOOD STRONG fuel UP TO the inj. pump.. but "crap" coming out.. Theres only 1 thing between them.. the injection pump..
If you need guidance getting it off, let me know..
PLEASE.. do not take the pump apart if you expect someone else to work on it.. it costs more & we're here to help each other out..& save money.
40' Shipping Container (A66285)
40' Shipping...
500 BBL FRAC TANK TRAILER (A65643)
500 BBL FRAC TANK...
2715SSFL (A61567)
2715SSFL (A61567)
1992 Jeep Cherokee (MPV), VIN # 1J4FJ78S6NL230132 (A65563)
1992 Jeep Cherokee...
2021 Ram ProMaster 3500 Box Truck, VIN # 3C7WRVLGXME588513 (A65563)
2021 Ram ProMaster...
2016 Ford F-350 Pickup Truck (A61568)
2016 Ford F-350...
