Injection pump tx 1300f ke70 engine
/ Injection pump tx 1300f ke70 engine #1
Jmorgan177437
El Campo texas
Iseki tx1300f
Looking for any info about the injection pump like disassembly smoke set i dont think its getting enough fuel pressure how would you check this any info would be great
/ Injection pump tx 1300f ke70 engine #2
What do u expect from a 2 cyl. machine.??
There are service manuals online for 35.00
The inj pump is nothing to fool around with..
I checked it it is good the injectors are working i have black smoke when it turns over i put new pistons and rings in it to fix the compression problem now it has good compressionbut still will not run any help please
/ Injection pump tx 1300f ke70 engine #4
Have u hung the injectors outside the engine to check their spray pattern.??
Just make darn sure you’re NO WHERE NEAR THE SPRAY.!!!
Set up a cardboard box about a foot or 2 away from the end of the injector..
Put the throttle in the start position and crank the engine over a couple of revolutions..& stop..
Check the cardboard..
It should be a small cone pattern..
Good luck..
Btw.. have u thought about tow starting it.??
/ Injection pump tx 1300f ke70 engine #5
It should have glow plugs. Have you checked whether or not they are functioning?
Good luck..
It has good spray i tried to tow start it but the tractor is not heavy enough to keep the tires from sliding it will not turn the engine but the starter turns it good no drag any advice.
/ Injection pump tx 1300f ke70 engine #8
Your head is in good shape? Valves seating properly?
Yes no leakage in intake or exhaust port when head was off had valves done anyway valves set at .014
Yes i have no compression leak thru the valves i had the injectors checked they pop off at 1600 well within specs glow plugs get red after 20 to 30 seconds i did put new pistons and rings in i cant seem to find a timing mark to line up pistons at top dead center for valve adjustment so i watch when the intake valve opens and closes before the exhaust vale opens and i set them when there is movenent between the rocker and the valve both closed and set them at .014 what could make it not run help???????????? I am lost
/ Injection pump tx 1300f ke70 engine #11
The assumption that we are all going by is that it ran well for you at some point. I'm starting to think that it has never run for you and this is why you are reaching out
What is the history of this tractor that made you start checking the injection pump, etc....
/ Injection pump tx 1300f ke70 engine #12
Strange there are no dots on the timing gears, my TX 2160 had them,
LAYMOR SWEEPMASTER 400 (A65643)
LAYMOR SWEEPMASTER...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A65643)
2020 TROXELL...
2013 KENWORTH T660 SLEEPER TRUCK (A65643)
2013 KENWORTH T660...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2018 Cat D6T LGP VPAT Dozer (A62679)
2018 Cat D6T LGP...
GREAT PLAINS TURBO-MAX 1200 - 12' VERTICAL TILLAGE (A64277)
GREAT PLAINS...
