Injection pump for iseki e3cd
/ Injection pump for iseki e3cd #1
Donald56
The manual for our MF1260 does not say where the injection pump is located;
nor does the little sketch of the pump match anything visible in or near the
engine compartment.
Can anyone tell where this pump is located so we can change the fluid in it?
/ Injection pump for iseki e3cd #2
The pump is on the right side of the motor, towards the front. It will have the three injection lines coming out of it. The owner's manual would have a picture to I think. That must be an early serial # tractor as the newer ones don't have a seperate sump.
I see the injecton pump but It does not look like the illustration in the owners instruction manuel. MF recomends changing the lubricaiton oil in the pump every 200 hours, but it looks like maybe it might be lubricated from the main oil system. Is that a possiblity?
Donald
/ Injection pump for iseki e3cd #4
Yes, it's the way the newer tractors are built. If the pupm looks like it's part of the block then it's lubricated with the regular engine oil. What serial number tractor is yours? It was around "E" Serial numbers that the change happened.
The serial number is E63804.
Thank You
/ Injection pump for iseki e3cd #6
Should be a newer model.
Winpower PTO Generator (A66408)
Winpower PTO...
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
7ft County Line Scrape Blade (A65579)
7ft County Line...
2012 Kenworth T660 T/A Sleeper Cab Truck Tractor (A64194)
2012 Kenworth T660...
2005 Acura RSX Coupe (A64557)
2005 Acura RSX...
2022 EZ-GO ELITE...
