Initial attachments to get with new Kubota L3560LE?
   / Initial attachments to get with new Kubota L3560LE? #61
Rule of thumb is 5hp pto per foot, so at 28hp at the pto you'd be between the 5 and 6 footer. If you're flat, mowing grass & not in speed racer mode, the 6 footer should be fine, you just may need to slow down a bit when in thicker stuff. The extra foot of width will make up for the slightly slower travel speed IMO.
Thank you. I like to stay within the published parameters, and I am in no hurry, so I think I'll focus on 5-footers.
I did a little research this morning comparing 5' cutters -- Landpride RCF2060, Rhino TW 15 and TW 25, Bad Boy 5', and Bush Hog BH215. Just based on specs, I am surprisingly impressed with the Bad Boy given its blade speed, 10 guage steel and slip clutch coming in at 718 lbs. (And apparently I can order one to pick up at my local TSC store). Do you guys have any thoughts regarding Bad Boy rotary cutters? Thanks.
LOT: (2) Gear & Pulley Puller Sets (A59076)
LOT: (2) Gear &...
Enerpac RCS302 30-Ton Low Height Hydraulic Cylinder, 5" Tall (A59076)
Enerpac RCS302...
2011 Komatsu GD655-5 Motor Grader, S/N 55088 C014007, PIN# KMTGD026P01055088, Turbo Diesel Engine, (A59076)
2011 Komatsu...
2020 INTERNATIONAL TANDEM AXLE SLEEPER (A58017)
2020 INTERNATIONAL...
2007 Tymco 500X Air Sweeper, Turbo Diesel, 3876 Hours Indicated, mounted on 2007 International 4200 (A59076)
2007 Tymco 500X...
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
