Buying Advice Info on mahindra 2538
/ Info on mahindra 2538 #61
I think I'll just run mine until dry and then see how much it needs to fill up again. Need to change fuel filter soon anyways so I'll be breaking open the fuel system anyways.
/ Info on mahindra 2538 #62
I ONCE ran a diesel "dry" (by mistake), and I will try to avoid a repeat of that mistake.
If you want to know how much your tank holds you might just try a measuring stick (if it is a straight shot to the bottom), or siphoning the tank dry.
Changing a fuel filter is a lot different than allowing the engine to run the tank dry.
With minimal effort, the diesel will likely pick up the fuel to start,..... after a fuel filter change.
After everything is run dry though ..... big pain in the axx!
/ Info on mahindra 2538 #63
If it's anything like mine, you'll drain the tank when you take the 1st fuel filter apart (the one with the cheap paper element) to change the filter anyway. It's best not to fill it up till you've changed the filters or you'll just be doing it all over again.
/ Info on mahindra 2538 #64
I read your post on this a few times. I was thinking of adding a shutoff in the line between the tank and first filter. I'm seeing several from small engine manufactures on Amazon- do you recall the hose size?
/ Info on mahindra 2538 #65
No all I can remember is that it has a banjo fitting on it I think. It might be safer just to cut the tube and add something inline.
I'd like to add something to the drain on the bottom of the filter can so I can check for water without needing to remove the engine access side skirt on mine. On the 1500 you can't access the fuel drain on the bottom of the filter without removing the skirt which is a PITA. Just screw a fitting in to replace the 10mm bolt and then some tubing and a drain cock should do it.
/ Info on mahindra 2538 #66
Ok I'll add a tee and 2 valves- one to shut off fuel at the tank and one to drain.
I won't be back to my tractor till next week. so I will measure then and order the parts. I'll take photos and post here.
/ Info on mahindra 2538 #67
I have been intently researching kubota & Mahindra tractors for awhile now. I have settled on a Mahindra 2538 Cab HST. With loader /backhoe, pallet forks & rear grader blade. I've did what I thought has been due diligence on the company & customer service performance. I have found some nightmare stores , not a lot, just a few that give cause for concern.... I would appreciate any feedback from any of you fellow members of tractorbynet on any good, bad & ugly experiences with your 2538... I'm second guessing my decision now..... look forward to hearing what has been experienced.
Jon
/ Info on mahindra 2538 #68
I bought my Emax22 from Jeff the guy who owns and operates the Mahindra dealer in Bethany Connecticut they are excellent and very knowledgeable and as they told me I will probably never have a problem with that particular machine and knock on wood I have not. And although I am a homeowner and it is a sub compact model I have worked the crap out of it and done some very heavy work and it has been great.
I priced it and compared the specs on the BX 25 and went with the Emax and I am very happy with it. Jeff and his brother are extremely knowledgeable of their products and I'm sure will be more than happy to show you their units as they did for me.
Go big red!
/ Info on mahindra 2538 #69
Mahindra is right in line with other major manufactures. See the attached report.
https://www.ne-equip.org/wp-content/uploads/2016/05/2016_Survey_Report_Final.pd_.pdf
I looked closely at the 2538 and 1538. Ultimately I settled on the 1538. The dealer had a good discount on it and I was willing to pay a bit more for the loader control next to the seat. With a cab model I would be hard pressed to go with the 15xx unless I found a dealer who had one and wanted it moved!
/ Info on mahindra 2538 #70
Jon
I am happier than a pig in mud with my 2538 HST! (Sometimes I literally am a "pig in mud" with the machine.) :D Stay in touch with your dealer/service techs if you see anything strange happen, but I've not had any issues. I would suggest asking your dealer to make sure they have the best ECU tune from Mahindra for your machine. Mine ran great initially, and then at 40 hours they updated the programming and it it's even better now. My hours are low at 60, but it's been run hard and nothing has been troublesome yet.
Go search through posts made by me to see some grapple capability shots and a load of other comments. You may decide you need a grapple afterwards! Hope it all goes well.
/ Info on mahindra 2538 #71
I like my 1538 too. So far so good with just a couple of warranty issues that were taken care of at no cost to me. One factory ECU code related issue and the other was a distributor related poor backhoe install issue. Otherwise a it has been fine machine that is approaching 100 hours on the clock.
/ Info on mahindra 2538 #72
Thank you all for feedback, the review data posted by dickfoster was great info to review and compare with other manufacturers.
/ Info on mahindra 2538 #73
Lol!!! Pig in mud... I'm itching to get the trees I had dropped mid December cut & stacked in the splitter area & start stump removal & grading the land for my future plans. The grapple will be happening at some point.... might spring for the backhoe thumb 1st ...... Should be getting my 2538 delivered 1st week of February...should I inquire about the latest ECU flash or see how it performs?
/ Info on mahindra 2538 #74
Ask about the ECU. I doubt it will be an issue now. When I purchased a few months back my dealer said he had upgraded everything on his lot already.
/ Info on mahindra 2538 #75
I would get both the thumb and the grapple, but I assure you in no uncertain terms that you will not regret a grapple if you have trees and stumps/roots to move around out in the woods. The picture below is a 60' EA Wicked Grapple and it has only been off the machine twice since I bought the tractor and grapple. Once I put the regular bucket on to move 20 yards of mulch this past spring, and the other time was... was when the tractor was new and I had not installed the grapple yet. :D
I thought I would be chaining and dragging logs around, but that requires getting off the tractor. A grapple is just a huge convenience and is very efficient and effective. (Plus you can run around with the cutter to get two jobs done at once.)
As to the ECU, I would ask the dealer to triple check with Mahindra on the version of the ECU program they are currently using. I believe there was one 2538 owner up north who was having a little bit of a rough idle and warm up after a recent ECU flash. I guarantee Mahindra corporate heard about that and likely tightened up the take points. They do seem to be tweaking the programming a bit on these new mCRD engines and maybe they went a little too far for the northern climates on that particular one.
I honestly don't know if my "newer tune" from late summer was the latest one or not, but it is now running in beast mode down here in Houston which rarely drops below 40 degrees during winter operation. Programming is easy to update, and if your dealer is close enough you could ask them to swing out with their laptop to do an update if there were any performance mods available down the road. My guy is close enough I can swing by with the trailer when heading out to property and the can just plug in the laptop and be off to the races in about 10 mins.
Check out this video of Ted using a smaller tractor to handle some chores around the house. Fast forward to eight minutes if you want to skip the discussion.
Good luck with your decisions!
/ Info on mahindra 2538 #76
Snowback,
Who is your Mahindra Dealer, I bought my 2538 from Cliff Jones and have been using J5 in Navasota as my preferred dealer due to loacation.
I am not sure there are any reasons for concern with them, I was just wondering who you used.
Steve
/ Info on mahindra 2538 #77
Snowback,
Steve
I picked my 2538 up at J5 in Conroe. Gene, Joel, Charlie and all the other the guys and gals are great! I've not been to J5 in Navasota, but assume they are great as well. In fact, I believe one of them may frequent the board, but I'll let him announce his presence if desired.
Gene and his crew even let me ship my Wicked Grapple and third function valve to their shop for installation. Very good customer service there. I think you'll be pleased.
/ Info on mahindra 2538 #78
Think I'll be sticking with J5 - wish I had bought the tractor from them!
/ Info on mahindra 2538 #79
Found this gem today. I have always been impressed with the super smooth steering of my 2538 HST, especially when the grapple is loaded with 1,500 pounds of tree trunks.
For those of you who are looking at both the Mahindar 2538 HST and the Kubota L3901, this may be of interest. Intro for about a minute and then they get into the demo. (The Kubota has many great points too to be sure, but this is just highlighting something with the Mahindra that was important to me - along with the rest of the beefy front end and tires for loader work.)
/ Info on mahindra 2538 #80
I thought I saw every comparison video on my fine tractor before I bought it.
I missed this one!
Sure am glad I bought the 2538!
I have not taken this beauty in for any warranty work since I bought it over a year ago (a little nod to God)
Only issue I have had is a stuck 4WD lever - which turns out it needed some grease between the housing and the washer where the arm goes into the block.
Everything else has been good so far.
2025 HD Trailer Solutions EQ15 T/A Equipment Trailer (A59230)
2025 HD Trailer...
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
2020 FORD F-150 XL EXTENDED CAB TRUCK (A59823)
2020 FORD F-150 XL...
UNUSED FUTURE X-PG44- 44" MINI HYD GRAPPLE BUCKET (A60432)
UNUSED FUTURE...
UNUSED RAYTREE RMBD72-72" HYD DRUM MULCHER (A60432)
UNUSED RAYTREE...
PALADIN GSS72-72" HYD BRUSH CUTTER (A60429)
PALADIN GSS72-72"...
