Info on JD 7200 tractor
/ Info on JD 7200 tractor #1
Dishpointer
Kansas
Ford 1600, Kubota F2690
Looking to buy a 7200 and am having trouble finding out much info on the 5.9 liter motor. Has anyone owned a 7200 or can give me any info about this tractor? Any info is appreciated.
Doug
/ Info on JD 7200 tractor #2
I think the 7200 actually had a 6.8 liter engine. The 5.9 liter or 359 cu in engines were used in earlier models like 2955, and 3155. The 6.8 liter is still used in current models and is an excellent engine. They were good tractors. They were still pretty simple tractors with minimal electronics. Is it cab?, powerquad?, MFWD? How many hours?
Yes it's a cab 2wd. Will mostly be used for haying. Thanks guys.
/ Info on JD 7200 tractor #5
jd110
According to JDparts & Tractordata the 7200 has a 5.9L/359 cid engine.
/ Info on JD 7200 tractor #6
The 5.9L engine is a good engine used in many JD units. The engine is known as being as the 300 series engines. What type trans does this 7200 have? The powershifts had a history of some shifting problems. My neighbor traded one off because of the problems.
Thanks for the info Jim. I'll have to find out what transmission it has as I posted these questions for a friend as he was worried that there weren't many made according to the serial numbers. I'll let you know as soon as I find out.
/ Info on JD 7200 tractor #8
TxJim is right it does have a 5.9 liter engine. I was thinking the beginning of 7xxx series was when the 6.8 liter began. Either way, both engines have been great. the 6.8 was designed around the 5.9.
2022 EZ-GO ELITE...
John Deere 4020 Loader Tractor (A66285)
John Deere 4020...
2017 FORD F-150 FOOD TRANSPORT TRUCK (A65643)
2017 FORD F-150...
Linx EQ07020RS 20ft Trailer (A65640)
Linx EQ07020RS...
90in. Work Bench (A65640)
90in. Work Bench...
2009 Infiniti G37 Coupe (A64557)
2009 Infiniti G37...
