info on gears
/ info on gears #1
chefirv
north providence, RI
ford 1210
I am new to tractorbynet so i would like to ask a question to all you tractor gear heads.
I have a Mckee 3 pt snowblower and am replacing the gears in it.
I can't find any info on this model out there
i have removed the gears but don't know what they call them
ie spider gears, beveled gears
i believe they are a bevel gear:confused:
are these standard on all 3 pt gear driven snowblowers
please any help would be greatly appreciated
/ info on gears #2
Need pictures. There are a lot of different types. You're probably needing miter bevel gears but there are different kinds of them too. I would assume these are for the right angle gearbox. You're probably going to have to find the manufacturer and get the gears from them. Not likely that Browning or someone like that is going to have anything that will work.
Kim
/ info on gears #3
You need to find an illustrated parts list to determine the part numbers. Replacing gears isn't just a matter of pulling the old ones out and sticking new ones in. They have to be set to a certain mesh (it's called backlash).
Here's a link I found on the web: http://www.yetmans.mb.ca/. Apparently McKee isn't in business, so you may have to do some research.
/ info on gears #4
I 'blew' the gearbox on a 3 pt snowblower a couple of years back.
I traced the OEM fabricator down and recieved a quote of $900. for a replacement .
The firm, Bervac, located in Drummondville, Que fabricated many models labeled under different known names.
Needless to say I abandoned the rebuild idea.
My unit was labeled as a Yanmar but was in fact built by Bervac.
/ info on gears #5
I have a 48" snow blower that was sold as Kubota model # 222A. They were sold to mount on the front of a B7100. It was built by Mcgee and sold as McGee model #220. It has the open bevel gears like I think you are talking about (not enclosed in a gear box housing). I really can't be of much help except that perhaps you could check with Kubota. I do have the operator and parts manual for this that I could scan and email to you.
/ info on gears
i would like to take you up on the offer.
it will give me a starting point.
could you email it to ikeighley2000@yahoo.com
it is the open gear box as you described
i do have a kubota dealer about 30 minutes up the road
with your info it would help out greatly.
thanks
/ info on gears #7
I don't have a scanner at home so I will scan it on Monday at work.
Massey Ferguson 383 Tractor (A64047)
Massey Ferguson...
(4) Trail Quest 235/80R/16 Tires and Rims (A64047)
(4) Trail Quest...
Bad Boy Z-Turn Lawn Mower (A64047)
Bad Boy Z-Turn...
2023 Kubota Z252KH-54 Zero Turn Mower (A63118)
2023 Kubota...
2012 MACK CHU (PINNACLE) (A63569)
2012 MACK CHU...
2020 DRAGON ESP 150BBL ALUMINUM (A63569)
2020 DRAGON ESP...
