Info on FF225
/ Info on FF225 #1
audiododd
Prescott, AZ
Kubota BX1500
Hi All,
I am the new owner of an FF225. I bought it used off a guy that had it for 3 or 4 years and was looking for a bigger tractor. Does anybody have any information on this thing? I can't find anything on the Internet about it. I know it's a 25 HP, full-time 4WD tractor. I know what MOST of the knobs/levers do, but not all and would be totally interested in a manual (owners and/or service) for it. the previous owner gave me a manual, but it's a generic photocopy that's for "most US & Japanese 3-cylinder models." It's pretty generic and older than my tractor model.
The only issue I have right now is a small fuel leak around the fuel distribution unit.
I'd also be interested in knowing what types of FELs will fit on it.
Thanks,
Dodd Martin
/ Info on FF225 #2
Hi All,
Thank
Dodd Martin
do you have a pic of that tractor. a ff225 my not be right
/ Info on FF225
Here are 2 pix of the tractor and one of the only placard I can find on it (unless there are some hidden behind body panels or otherwise inaccessible). It looks similar to the F22D and the F245D/F255D. That's about as close as I can get. The placard has 2 numbers and I assume one is the serial number. The 22C MIGHT be some type of model number, but it doesn't seem to match anything I could find online. The FF225 is listed on this site (Japanese Used Tractors and Farm Machinery -MISH JAPAN TRADING CO.-) but there's only a pic, no info.
Thanks for you help!
Dodd
/ Info on FF225 #5
Not to be a downer, but the FF225 is a no frills tractor as far as the F series goes.
I believe its full time 4x4 , no power steering, no quick turn, and an aluminum housing on the back like the F18.
Im glad to see that yours has the UFO option !:thumbsup:
I had one here for sale about 5 years ago.
It takes a koyker 125 loader with the F215 mount.
Hope that helps:D
What is the fuel distribution unit, please provide a picture....
Your land has a nice view !
/ Info on FF225
Ernie,
Yep. Definitely no frills. It's what I needed though. Something to disc/till/mow/move dirt with. We just bought 5-acres in the bay area and about an acre is walnut orchard and the rest is the house or undeveloped. The price was right. Once the sun is up, I can try to get a close up of the fuel leak area.
The tractor apparently has a draft control lever, but from what I've read it only works with a special connection to the implement. Not like a traditional draft control. There is a small lever under the seat (there's a threaded post with a wing nut on it) that I can loosen and move back and forth. Anyone know what that does?
Dodd
/ Info on FF225 #7
You may have hyd lines under the rt side floor board. if so I think that wing nut deal is a open/close for those lines.
/ Info on FF225
Ernie (et al),
Here are two views of the fuel distribution unit. You can't see it here, but there is a small amount of fuel on the top of the unit. It appears to be leaking from around one of the compression fittings.
Runningbird - I do have hydraulic lines under the right floorboard. In fact, it used to have a FEL on it, but the last owner got rid of it because it was in the way for him driving around his orchard. He just pulled the lines and linked them together with a coupler. That will make it stupid easy for me to add an FEL in the future. I'll have to keep my eyes open for a nice used one (if I can find one).
Hope everybody had a good Christmas and will have a great New Year!
Dodd
/ Info on FF225 #9
It looks like you need to tighten those 3 lines on top first, then the caps on the lines. They are a pain to tighten because they are to close together, so have patience...
Hose it all off and let it dry, or use an air line to blow it all off, then inspect for more leaks with a flashlight.
Your fuel dist unit is an (injection pump)
:D:D:D
Ernie
/ Info on FF225 #10
I run the 3 point chipper off those two lines on the FX335, works great !:D
/ Info on FF225
Ernie,
Now that Spring has sprung, I'm more willing to get outside and work on stuff (not that we ever got a good winter out here). I cleaned off the injector pump and cranked the old girl up. It seems that the fuel is leaking from the right-hand connection. If you notice in the pictures I posted earlier, the "clamp" (for lack of a better term) that holds the right two outlets together is a couple of mms higher than the left one. I don't know what the function of those clamps are other than to keep the bottom connections from turning.
I assume that the top connections are standard compression fittings. Should I loosen the top fitting, tighten the bottom one, and then re-tighten the top one?" If that doesn't fix the problem, I guess I'm looking at replacing the injector line and maybe the fitting that goes into the pump.
Thanks,
Dodd
/ Info on FF225 #12
The lines use copper washers on the banjo fittings, if they are missing, it will leak.....:D
2006 Ford F-750 Terex Commander C4047 Digger Derrick Truck (A68183)
2006 Ford F-750...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
UNKONW  TRIAXLE ALUMINUM VACUUM TRAILER (A67714)
UNKONW TRIAXLE...
Set of 4 Unused 10-16.5N.H.S. ForeRunner Skid Steer Tires (A66734)
Set of 4 Unused...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A66734)
2025 Kivel 48in...
Skidded fuel cell (A67714)
Skidded fuel cell...
