Tractor Sizing Info for 86 horese JD 3120 Tractor
   / Info for 86 horese JD 3120 Tractor #1
ddoby
Kaufman, TX
John Deere 3120 & New Holland WM45
Does anyone have any info for the 69-71 86 horse JD 3120 tractors? I can't find much. Everything I find under 3120 is for the newer compact tractors.
   / Info for 86 horese JD 3120 Tractor #2
Check and see how similar this is to a 3130. IIRC the 3130 is 86hp too and should be very similar. Is yours a 6 cylinder?
What kind of information are you looking for?
   / Info for 86 horese JD 3120 Tractor #3
Most likely a Canadian or European version of the 3020. Put Model 3120 in the model search of JDparts and see what comes up.
   / Info for 86 horese JD 3120 Tractor #4
It is different from the 3020, more the size of a 4020 but not as good imo.
This 3120 he is inquiring about is a 6 cyl tractor with a 303 cu in engine which is about half way between the 3020 and 4020 engines.
I agree it is an European version with parts that are more difficult to locate in most cases.
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2021 Ford F-150...
John Deere 2640 2WD Tractor with 146 Front Loader (A55302)
John Deere 2640...
2021 Ford F-150 XL (A53314)
2021 Ford F-150 XL...
2001 Ford F-350 (A55788)
2001 Ford F-350...
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
